Question about Fisher and Paykel GWL11 Top Load Washer
GWL 11 Code 109
What is fault code 109 mean ?
5 Suggested Answers
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Posted on Oct 09, 2009
  • 713 Answers
SOURCE: GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Posted on Jun 23, 2010
  • 713 Answers
SOURCE: Fisher and Paykel GWL 11
Hi just read your posting.Try this,Put a couple of books under each foot of the machine high enough so you can look under the machine at the pump.Now select a spin mode and push the start button.Does the pump turn on its own?Where is your machine draining the water to,Is it into the laundry sink or some place else.Please reply with this additional information and this will help me in diagnosing this fault for you.Looking forward to your reply.
Posted on Oct 05, 2010
My 94 Nissan Altima ECU is giving code #21. This is for Ignition signal. Haynes manual says, "See dealer". It is also coding #11 - camshaft sensor.
Code 11 crankshaft position sensor or Camshaft position sensor. Code 21, Ignition Signal, Diagnostic Tree . Best to take to dealer for repairs and to remove codes, the codes do not mean the units are faulty ,just there is a fault, could be just a bad connection.
Mar 19, 2015 | 1994 Nissan Altima
I ran the diagnostic on my fisher and paykel gwl 11 and it has a fault code 51. Is that more than just a diverter value?
This is error code 51
51. (00110011) Phase 5 and 6 Eco - Diverter Valve Fault
Primary: The motor controller has registered a drop in water level in the
recirculation phase of the wash cycle, water is being drained instead of recirculated.
Or water has been sprayed onto the Valve from an external source and caused the
solenoid to blow.
Action:
Turn the power off at the machine but leave the power on at the wall, then measure
the voltage across the terminals of the wax actuator, if a reading of 230V is
achieved the motor controller has failed due to the valve and both will need to be
replaced.
Secondary: Check for blockage in the valve itself or a broken hinge mechanism.
Mar 12, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
How to install fuse gwl11
You need to be more detailed in the description. What is the fault code & is it the same code as before the pump was changed? Why did you change the pump? Was the old pump tested & proven to be faulty or did you just change it in the hope that it would fix the fault? I have changed many F&P smartdrive pumps & never seen or heard of any having a fuse. The only fuse is on the main control board, soldered in. If that had blown the machine would not power up, so fuse must be okay. Start from scratch & say what the error code is.
Jun 08, 2017 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL 11 is getting the error code 37. Checked for blockages, none found and pump operates normally, no sounds, impeller turns freely. Still will not drain in spin mode. Any suggestions?
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Code 1494
Did you mean p1494? If so then its your evaporative emission ventilation switch or a mechanical fault, probable causes:
  1. Evaporative Emission Ventilation Solenoid failed
  2. An open or short circuit.
  3. Vacuum hose clogged.
  4. PCM Failed
Check the following:
  1. Check the following connectors: A-109, B-76, B-63, A-107. Repair if needed. If its ok then check:
  2. Check the harness wire between the Evaporative Emission Ventilation Solenoid connector. If its ok then:
  3. Replace PCM
This information was retrieved from AllData :
Sep 10, 2009 | 1998 Dodge Grand Caravan
Fisher paykel codes
Apr 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Error code 11 - pioneer avic 1r
From Pioneer;
"Error code 11 is more specific, however, indicating that the player’s read laser cannot focus properly, most likely due to a fault with the disc."
Try a different CD, or you may have to have the laser cleaned.
Best of Luck.
Nov 17, 2007 | Pioneer GPS AVIC-X1 car radio
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
