Question about Timex Watches
Timex SB 621 SW CELL L8 replaced battery-- Back will not fit back on. What's wrong?
We took the watch back to Wal;-mart. They replaced battery ,but couldn't get the back back on. The watch insides seems to stick up too far--about 1/32 of an inch. Solution? Thank you Ray at : ray4116@gmail.com
5 Suggested Answers
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
escapement
  • 2334 Answers
SOURCE: timex watch cover replacment
Align the caseback exactly as it was before you opened it. Make sure thet the groove for stem is in correct position. Lay the napkin on the flat table surface, put the watch on it (dial down) and using both hands and your body weight push the caseback down back in place. Remember: the side of the caseback wich first came out must be last pushed in.
Do not use very soft napkin (towel) as this can brake the glass under the pressure.
If all above described DO NOT work, then there is not enough power in your hands or not enough weight in your body and you will need watchmakers help (he/she will be using special watch press to close the watch).
P.S. Do not get upset if you can not close it; I'm very expierenced watchmaker and very often came across the watches wich I was not able to close without the watch press (even my arms are quite strong and the weight is 95kg).
Do not forget to rate, please.
Posted on Mar 07, 2009
SOURCE: Military Time
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
Chris
Posted on Aug 31, 2009
reyjoshua07
  • 1157 Answers
SOURCE: instructions for Timex CR 2016 748 L8
Hi m_cox840,
If you don't have the manual, this is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
Posted on Aug 15, 2011
Replacing the battery on a HAMLIN watch
Go to Wal-Mart to the counter where the sell watches they have a tool made for that.
Mar 06, 2013 | Watches
Instructions for Timex CR 2016 748 L8 (Wanted)
Hi m_cox840,
Hope it helps.
Aug 13, 2011 | Timex Mid Size Sports 1440 Coach Black...
How much is the cost of replacing a battery on my tissot prs200
If you have tool and do it at home, it costs you about $4.00 for the new battery bought from Wal-mart. You have to open the watch's back to see the battery type (for example Renata or Maxell or Varta, etc. together with a 3-digit number) then go to Wal-mart or somewhere else to buy a replacement.
If you can't do that by yourself or don't want to get some scratches on your watch, bring it to your local watches/jewelry store. ( I have paid for that small job $16.00 plus taxes.)
Feb 16, 2011 | Tissot TSport PRS200 Chronograph T17148644...
How to remove battery from columbia CL-5012 watch
Take It Too a Place Like JCpenny Store or Sears or Wal-Mart or Target & They Can Remove Battery Things From Watches as Well as Replacing Battries Too Have a Nice Day.
Nov 27, 2010 | Columbia Sportswear All Sport Digital...
I have a Timex Ironman 30-Lap Mid watch with a dead battery. I purchased a CR 2016 battery as stated on the back cover of the watch. How do I change the battery?
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
Sep 19, 2010 | Timex Watches
How do I get the battery cover off of the 2005 logoart pitts steeler watch? Has spinning face with gold/silver plated band..
At a watch shop is the only safe way.
I've done it with needle nose pliers and scratched the watch every time.
At the watch shops they have a tool, even most wal marts and sears have watch battery replacement centers where they do it for the cost of the battery (no extra fees)
L8ers
Sep 12, 2010 | LogoArt Pittsburgh Steelers Men's NFL Pro...
Strap broken on timex heart rate monitor watch 30 lap ironman triathlon need a replacement
Hi, Almost any large dealer like Wal-Mart, Sears, or Target will have Timex replacement straps and bands for most popular watches and monitors. Sometimes a local Authorized Dealer will have specialized products that the department stores don't even carry without ordering.
I have had good luck with Wal-Mart on watch accessories. I've also ordered straight from Timex in Little Rock, Arkansas, ph. 1-800-448-4639, but it usually takes more time for just parts.
Thanks, Bill
Sep 06, 2010 | Timex Ironman T59761 Midsize 30 Lap...
Brokem wrist band
Check Wal-Mart, Sears, Target, or other large department stores. Many carry a good selection of replacement bands for Timex. If you still don't find one call Timex in Little Rock, Arkansas at 1-800-448-4239.
I hope this will help you replace your band.
Thanks, Bill
Sep 04, 2010 | Timex 30 Lap Ironman Fast Wrap Midsize...
Watches Logo
124 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
