Question about 2wire 1800HG Router (RG1800HG00)
Ip camera logon ptoblem
I'm able to access my ip camera on my LAN but can't from a remote location using the internet. I have tried the configurations listed on the camera instructions as well as the 2Wire 1800HG modem/router regarding port forwarding. Your thoughts please!
Les Speckert
    Genius:
  • 1,268 Answers
You might have forwarded the wrong ports of the camera to the wrong IP address. Make sure you assign static IP on the camera. Firewalls should be turned off as well.
Posted on Oct 28, 2008
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
Connecting wireless cam with different ip address
An IP camera is a video camera that can be viewed over a Local Area Network or the Internet. The camera typically is monitored locally from a computer via the network to which the camera is attached. With just a few additional configurations of your network, you can access the IP Network Camera so that it can be monitored remotely using the Internet. This is the benefit of a network camera, as it can reside on an IP network and the video stream can be accessed or saved remotely.
Get the Default Gateway of your IP. Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yourself known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it.
Viewing an IP Network Camera over the Internet http://www.networkcamerareviews.com/articles/portforwarding.html
Apr 18, 2013 | ASI Trendnet Wireless Tew-639Gr 300Mbps...
How to connect an ip camera with a different ip address
Apr 18, 2013 | Computers & Internet
I do i get the default username and password for vivotek fd8134 camera
Get the Default Gateway of your IP. step 2 Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yours lf known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it. Hope it helps.
Jan 23, 2013 | Vivotek FD8134 - Network camera - dome -...
I have a Buffalo WBMR-G54 ADSL Router. The local IP address of the router is 192.168.1.1. My Medion desktop computer connects connects to my Buffalo router using an Ethernet cable. I use the wireless...
> Zone Alarm free firewall and Avast antivirus have been installed on both computers
Your router is already acting as a "firewall" to block "unsolicited" traffic from reaching the computers on your LAN. So, unless you use Zone Alarm to block "outgoing" connections
(such as a computer-virus would try to make when "calling-home", there's little benefit
to using the Zone Alarm software.
> If I use Internet explorer to connect to http://myname.dyndns.org, Internet Explorer does connect successfully to the network. However, it invites me to enter the username and password for my Buffalo WBMR-G54 router - not for the storage drive.
While you are "forwarding" TCP port 21, you are not "forwarding" TCP port 80 (as used by the 'http://' protocol). So, when you connect from the Internet to your "public" IP-address, it is the router that responds, rather than one of your computers inside your LAN.
IMHO, it is "bad" that your router's web-interface is "exposed" to attacks from the Internet.
Either "forward" TCP port 80, or configure the router to use a _different_ port number for "remote management".
> If I enter the Router user name and password, that allows me to access the Router menus via the Internet, which confirms that my account at DynDns has translated the IP address successfully.
Correct. Hopefully, you're the only one who knows the correct username/password, and there is nobody that is doing "brute-force" attacks on your router, trying to login to "hijack" your router.
> if I use Internet Explorer or FileZilla to access ftp://myname.dyndns.org, I cannot connect to the router
Correct. The 'ftp://' protocol uses TCP port 21, which the router is "forwarding" to one of the computers on your LAN.
> or the storage drive - so I cannot access any of my files remotely.
> FileZilla reports -Status: Resolving address of bob1944.dyndns.org
> Status: Connecting to 78.144.xxx.xxx:21...
> Status: Connection established, waiting for welcome message
So far, so good.
Is FileZilla expecting a "specific" content in that "welcome" message, or will "any" response be "close-enough" ?
On a computer on the Internet, open a command-line prompt:
Click Start
Click Run
Type CMD
Press Enter
Enter FTP bob1944.dyndns.org
Press Enter
Do you get a "connecting" message?
Do you get a "connected" message?
Do you see the "welcome" message?
Note that the FTP protocol usually uses _two_ ports for File Transfer:
* port 21 for "control" (sending/receiving commands/responses)
* a "random" port for "data" transfers (including directory-listings)
It's this "random" port that your router is not forwarding.
However, some FTP-clients (probably including FileZilla) and some FTP-servers
support "passive" mode, where both the "control" and the "data" connections "share" port 21.
So, configure FileZilla to use "passive" mode, and _hope_ that your FTP-server supports "passive" mode.
Jan 06, 2011 | Buffalo Technology WHR-G54S Wireless...
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
2wire 1800HG Router (RG1800HG00) Logo
315 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
