Question about Xerox Phaser 6180N Laser Printer
Xerox phaser 6180 smudges - Xerox Phaser 6180N Laser Printer
    Novelist:
  • 217 Answers
If these look like a little squiggles, repeated across the page AND down it, at about 1" spacing.
They are cause by a component in the toner cartridge.
Originally the cleaning roller was a plain roller, but at some time the 'bean counters' decided they could save a tiny bit of money on each cartridge by using a spiral foam roller instead. The foam also seems to be of a different type, and doesn't age well.
There are two solutions.
1. Replace the cartridge that is producing the coloured squiggle/
2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
Posted on Nov 24, 2015
  • 2072 Answers
SOURCE: Xerox Phaser 6180 uses too
In all honesty, its not that they use to much toner. Xerox does NOT put nearly enough toner in their cartridges to get the proper yield.
I have gotten as low as 200 pages out of those cartridges.
I do service on them and they do not give 1/5th the yield they advertise.
Nothing you can do to be honest. But they are hugely inefficient.
Posted on Aug 13, 2008
  • 2072 Answers
SOURCE: XEROX PHASER 6180 LASER ERROR
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
Posted on Sep 04, 2008
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
SOURCE: Xerox Phaser 6180 MFP-D password
The default password is "00000" If this password does not work you can follow the following to reset it:
  1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  2. Press and hold the [OK] button on the Control Panel.
  3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
    NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
Posted on May 29, 2011
SOURCE: I have a Xerox Phaser 6180. I have not had any
I have 4 of these printers and when we print lots of manuals in full colour and duplexed the printers occasionally get to hot and need to cool down. After a 1/2 hour they are good to go again. I wouldn't worry about it, it happens only when it gets lots of use and I have never had anything go wrong with the printers after these errors
Posted on Sep 25, 2011
Xerox phaser 6180 has error code LPR and blue horizontal marks in background show up.
Background is usually a cleaner unit fault, need to check out more on this point. Best to start from this point and try this to see if you can make changes.
Good luck.
Oct 06, 2014 | Xerox Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6280 Y CRUM ERROR
The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
I have an older Phaser 6180 printer that was never used until i opened the box today. I think it was a 2007 version but never opened. I connected it to my windows 7 computer with usb and while...
You most likely need a Windows 7 printer driver.
Go to the Xerox WEB site to download the printer driver -
http://www.support.xerox.com/support/phaser-6180/downloads/enus.html
Jan 19, 2011 | Xerox Phaser 6180N Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
When I print jpgs with the Xerox Phaser 6180, they print with a pink box around them
Have you tried loading a different print driver? I know the PS Driver is recommended for a phaser, but see if they have a PCL 5 or 6 and see if simply replacing the driver resolves the issue.
Dec 29, 2009 | Xerox Phaser 8500/DN Printer
You more than likely need to place a service call.
Over temp can be related to the fuser control circuits,
Don
Dec 15, 2009 | Xerox Phaser 6180N Laser Printer
How to replace the waste container in phaser 6110?
The easiest way I can tell you is this.
GO to Xerox,com, click on support and drivers.
THen the search box comes up type in phaser 6180, then enter, when the next screen displays click the support line for the 6180, In that search boc type in replace waste and step by step directions with photos come up,
Its the best place to go to find that information.
Jul 18, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 6180N Laser Printer Logo
69 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
