Question about Snap Sights Intova IC 600 Digital Camera
I need the inside silicone seal for a Intova ic 600 camera houseing
The houseing has two seals. One on the houseing door and one in the inside of the houseing. I need the inside seal it appears to be silicone
3 Suggested Answers
SOURCE: problem with the lense of intova IC 600
Hi Abir,
I had the same problem with my camera, the shutter was stuck halfway and wouldn't open or close after that and the controls were also frozen. Turns out that one of the small gears that moves the shutter and zoom was broken. Take the camera to any good digital camera repair shop and they can fix it. Costs about 20$ though. Hope this solves your problem.
Dr Partha
Posted on May 03, 2010
  • 67 Answers
SOURCE: hi hm mohamed from egypt
Hi mohamed,
Please call Intova directly at +1 808 837 0074 or email us at kevin@intova.net and we will help you with your IC 600 problem.
Thank you,
Intova
Posted on Jun 28, 2011
Intova ic12 green error message on viewfinder shutter not closing any help
Hello jan_c19,
This sounds like a defective IC12 camera. Please contact Intova via email, fatema@intova.net or call us at 808-837-0074 for customer service. Thanks
Jun 02, 2012 | Intova Ic12 Digital Camera
INTOVA
Hi Pat,
Maybe it could be for some minor glitch. Try the steps given in the link below to help you know better about your camera.
Troubleshoot Camera Issue
Regards,
Suhail
May 15, 2012 | Intova Ic-14 Sports Digital Camera & 180...
Hi im mohamed from egypt i have intova ic 600 bat lcd its damedg if you can tshang and haw matsh ?
Hi diver65_11,
Unfortunately we do not have replacement LCD for our Intova cameras. If you wish to upgrade to a newer model, please contact Intova directly by emailing fatema@intova.net . Thanks
Jun 28, 2011 | Snap Sights Intova IC10 Digital Camera
Hi hm mohamed from egypt i have intova ic 600 bat lcd its damedg if you can tshang and haw matsh ?
Hi mohamed,
Thank you,
Intova
I have had my Intova IC 600 for almost a year. Recently I was getting a "Card Error" message. I replaced the card, but the message won't go away. I have tried to reset the defaults, but the message won't...
You probably just need to format the card in the camera to get it to work. This will erase the card so download any pics first using a card reader if necessary.
Mar 28, 2010 | iClick Intova IC800 Digital Camera
I have an Intova IC 600 and the lens is stuck out.. hear the motor running but doesnt slide back in..
Hello mond328,
It sounds like your lens retraction gear has become disengaged. It is possible to gently push the lens inward to re-engage the gear. If this doesn't work, then the gear may be stripped or broken. If this is the case, then it isn't cost effective to repair the camera. Unfortunately, IC600 is a discontinued model for which we do not have any replacements. We do however have other cameras with similar waterproof capabilities. If you are interested, please call us directly at 877-837-0074 or 808-837-0074 or email kevin@intova.net .
Best Regards,
Intova
Mar 04, 2010 | iClick Intova IC800 Digital Camera
Problem with the lense of intova IC 600
Hi Abir,
Dr Partha
Feb 21, 2010 | Snap Sights Intova IC 600 Digital Camera
HOW TO AVOID GET FOG ,CONDENSATION INSIDE THE HOUSING
Mothers rubbing compound gets rid of gunk on your head lights, and keep the plastic lubed up, get some silicone II "aviation glue" to create a tighter seal to keep; water from going in around the lights edge sondensation may still built up but on the inside
Dec 13, 2009 | Ikelite 6038.02 Underwater Video...
Dishwasher seal issue
I use ge silicone clear sealant it is flexible adhesie that can handle water and heat
You can get this at Ace or big box stores you do not need a big tube
FIX:
1 Open dishwasher door
2 gently pull rubber seal away from dishwasher guide You do not have to remove the entire seal unless it is loose just keep pulling until you feel the seal staying on dishwasher
3 put a small amount of clear sealant on loose seal(side facing housing) and small amount on dishwasher guide ( dip your finger into water so that it does not stick to your finger)
4 press the seal into place on dishwasher housing
5 wipe excess with a damp cloth be sure you do not get any on seal side that faces dishwasher door
6 Allow to dry over night
Good Luck
Jan 02, 2009 | Kenmore Dishwashers
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Snap Sights Intova IC 600 Digital Camera Logo
14 people viewed this question
Top Snap Sights Cameras Experts
Are you a Snap Sights Camera Expert? Answer questions, earn points and help others
