Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED
flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then
flashes RED. Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED
flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then
flashes RED.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Possible error on JB board - diodes D5701, D5703, D9616. Replacing them should be sufficient. Anyway, you
should contact the nearest Sony Service.
Regards,
Arpi
