Question about Ridgid Air Tools & Compressors
I have a Ridgid angled finish nailer. it puffs out air but no nail. What to do??
My nailer has been working fine then without any notice it quit sending out nails. All I get is puffs of air. What can I do to fix this?
SOURCE: paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
Posted on Nov 04, 2008
  • 1388 Answers
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
It can be confusing these days knowing exactly how each nailer works. For example your nailer has three different triggers available that will function differently. The black trigger is the contact trigger that will fire a nail every time the safety hits the work or (bump fire with trigger held); with the grey trigger one must depress the safety foot against the work first ~ then squeeze trigger. To fire again you must release the trigger withdraw the gun ~ re-depress the safety and squeeze the trigger to fire again. A third black trigger is available that will fire the gun with mechanical arm for production work. You can test the gun for defect by disconnecting air, removing the nails, remove the trigger retainer pin, remove the trigger. Then connect air and press the gun against wood and press the trigger pin with your finger. Not good to dry fire these guns; thats why it is necessary to place gun against wood to absorbe energy. If the gun does not fire return for exchange. Good Luck
Posted on Jan 25, 2009
  • 1388 Answers
SOURCE: BOSTITCH 2IN1 VENTS AIR AND WILL NOT FIRE
Your nailer is one of many bostitch nailers that use the TVA6 trigger valve. With time, this triggering valve will wear and act as you describe. Some TVA6 valves have a green plastic pin that wears and becomes shorter. (some have a metal pin) The safety foot and trigger can also cause problems. Try the following to determine the problem:
Remove the roll pin that holds the trigger in place to expose the tva6 valve pin. Remove the nails from the gun and connect airline. Place the nose of the gun against wood or hard rubber and with a very quick motion depress the trigger pin all the way in. If the gun fires then the problem is that the safety and the trigger are not depressing the tva6 pin all the way in. Check for worn parts and replace as necessary.
If gun does not fire remove the head from the gun and check headvalve for worn orings or very tiny scratches where orings contact surfaces. Use a magnify lense to check surfaces if necessary. Use very fine sandpaper to remove scratches (300 grit). Lube orings with silicone paste (looks like vaseline, sold at Lowes in plumbing department it is used to lube faucet orings) and re-assemble. This will make your nailer regain lost power.
Finally, when the tva6 valve fails, air will leak out valve at a high rate, however as the valve wears it will become troublesome if you have a plastic pin. To replace remove trigger then remove roll pins that retain valve. Use a thick glove to catch the valve as you connect to air supply. Use caution because it will come out with force. You may want to reduce pressure to gun when you do this. Good luck with your repair and email if you have question.
Posted on Feb 24, 2009
  • 1388 Answers
SOURCE: DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Posted on Jun 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
Ridgid r350rhd-round head framing nailer the nail is jammed in backwards behind the push rod. don't ask me how it is backwards
FYI The fact that you've managed to flip a nail in the nose can suggest a nail that's too short. Rule of thumb is that framing tools use from 50mm (2") up.
Sep 20, 2013 | Ridgid Full Round Head Framing Nailer...
The piston in my ridgid roofing nailer comes out and wont go back by its self
This problem occurs when check band is not in place. Remove the head and pull out the cylinder. There should be a rubber band around a series of holes on the cylinder. Replace if broken or just put back in place. Good luck
Jan 20, 2013 | Ridgid 21168 212" Angled Finish Nailer
Roof coil nails any diffrence
Internally they are the same, however the rnd has a semi clear cover to see the coil nails in the cannister (could be other differences but use same nail). There is a difference between brands of nails. Check with local code for required length and type (galvanized , stainless etc). Make sure that the wire that binds the nails together is not too strong and stiff. Some coils have soft copper that works quite nicely and others use a stiff steel wire that tends to pull at the coil and leaves a stiff piece of wire in front of the first nail preventing good alignment to driver. If you are going to depend on your nailer for daily work, order and have in stock upper bumper and cylinder seal. These parts will fail quite quickly. Other parts tend to hold up pretty well. Good luck
May 31, 2012 | Ridgid ZRR175RND FactoryReconditioned 134"...
I need the operators manual for this product. How can I get one.
Go to the Ridgid webpage on your gun at: http://www.ridgid.com/Tools/R250AFA-Nailer/ You can downloak an owners manual or parts list in PDF format. Just click on the little icons under the model number. The files are fairly big so, depending on your connection speed, they do take a little while to download.
Mar 11, 2011 | Ridgid 21168 212" Angled Finish Nailer
Will the nt65ma3 use fn style finish nails
(fn) stands for finish nail,,, and there are different types of those,, this hitachi will use 15 guage, angle finish nails,, do not attempt to put 16 gauage strait or 16 guage angle nails in this gun,
Dec 04, 2009 | Hitachi NT65MA3 2 1/2 Inch 15 Gauge Finish...
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Air Tools & Compressors Logo
47 people viewed this question
Top Ridgid Air Tools & Compressors Experts
John Trevino
john h
Are you a Ridgid Air Tool and Compressor Expert? Answer questions, earn points and help others
