Question about Microwave Ovens
Maytag MGR5730BDW gas range to unlock code - Microwave Ovens
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: maytag MGR5730BDW gas range oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jul 05, 2011
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
Maytag MGR5730BDW gas range oven do not bake, the automatic pilot turn on but burner bake don't start
heatman101
Jul 04, 2011 | Microwave Ovens
Maytag microwawe model mmv4203dw00 the control board is showing a trouble code e5 unit wont go on i try unpluging from the outlet to reset it but still it wont work
Actually it can't be "dead" if a fault code is on the display.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
It should tell you what the E5 code means, but I would suspect a defective temperature sensor or control board.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jun 06, 2011 | Maytag Appliances Over-the-Range Microwave...
Error code F9 and lock on computer On Maytag gas range.model mgr587bdb.
The F9 error code refers to the door latch. The problem seems to be with the latch motor or a switch associated with the motor. If I am reading your question correctly you say that it would not unlatch and then upon resetting it unlatched but the oven won't work and you still get the error code. If so try resetting again but have someone come out to check it out or you will continue to have this problem.
The F9 indicates one of two possible problems. One you have already done and the other is the door lock mechanism. If the lock mechanism got stuck in between the lock and unlock neither switches on the lock mechanism are closed. This could be caused by a post on the lock mechanism that has failed.
I just looked up the part for the door lock and it is no longer available, with no other source for the part.
So I guess I would suggest having a technician come out and see if he can see if the lock mechanism can be fixed so the oven will work but you will no longer have the clean cycle working.
They may or may not want to do this for you, but you could use a local service company and they may be able to make it so you can use your oven.
I hope this helps (remember to rate and comment this answer).
May 12, 2011 | Microwave Ovens
Error code SE on Maytag Microwave
The error code SE stands for " Systems Error " which indicates there is a short in the keypad membrane causing the system to lock up. The only option is to have the keypad replaced for normal operation.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
Locked timer/keypad
Try unplugging it for a few minutes. If that fails, read the owners manual for instructions on how to unlock.
Jun 26, 2010 | Maytag Appliances Over-the-Range Microwave...
What is the building code for the distance from the bottom of the microwave to the cooking surface below? I have a Maytag microwave that was manufactured in May 2002 and a Maytag Gemini gas cooking stove.
You can check the owner's manual or installation instructions for what the manufacturer stipulates.
If you don't have them, you can download them here.
For building codes, contact your county or city government offices.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Maytag Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
