Question about Gateway Computers & Internet
I have an old gateway model #micro atx san professional v733se that I need to see how you plug in monitar, mouse, all the stuff at rear of tower. The machine will power up at the tower, but the monit
I have managed to loose over the years, the diagram that was sent with the origional machine that showed you where to plug in the wires on the back of the tower that operates everything. I think I may be missing a wire somewhere...the tower lights up, sounds like it is running, the monitar comes on and shuts right back down again. I even tried putting one of the restore disks in the slot to see if that would kick it in, but nothing has happened
SOURCE: My keyboard and mouse
Underneath the keyboard there should be a series of number . this should be the id.
let me know if this helps.
Posted on May 09, 2008
SOURCE: Monitor goes blank during uptime
I had the same problem - was the motherboard capactitors.
Dell extended the warranty on those motherboards because of the fault until January 2008. Unfortunately I only found that out in February :-(
Still, I bought some replacement capacitors from www.badcaps.net replaced the faulty ones on the motherboard and all is now running sweetly.
Posted on May 22, 2008
chaw18
  • 10 Answers
SOURCE: no mouse,no keyboard, and no monitor?
try to connect it with other keyboard,mouse and monitor....if they will run, the keyboard,mouse and monitor may be defective or damaged..but if they did not run properly,,
maybe somethings wrong wit your unit...
try to connect it first and see whats the result...
please tell me what are the results...
you may post it here...
chaw
Posted on Jun 23, 2008
SOURCE: Only the left rear trailer light comes on when I apply the brakes.
I had the same problem with my 2002 Silverado last summer when I first bought my boat and was getting the trailer ready to go. Like an idiot, I rewired the boat trailer on that side before I decided to look at the owner's manual. The pickup has separate fuses for right and left side of trailer. They're located in the big box in the engine compartment. I replaced the 10 or 15 size fuse and haven't had a problem since. Hope this helps!
Posted on Apr 26, 2009
  • 263 Answers
SOURCE: emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Posted on Jul 30, 2009
Motherboard Brand and Model Number
This case will fit any motherboard that are Micro ATX or ATX format.
Jul 08, 2014 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
What name is given to a power supply whose case has the following features: ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 Extenal 5.25
If you need a PSU you need to do a google search to find the exact match.Micro ATX,ATX, and ATX Mid as the name are the size of the PC case.
Apr 18, 2012 | Computers & Internet
P4 to Dual-Core in OPptiplex GX270 with Micro atx
You will need to make sure that you have a micro ATX form factor when you buy a replacement and that you have the slots for all the hardware that you want to add. For example: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5633664&CatId=1533
Jul 19, 2010 | Dell OptiPlex GX270 Small Mini-Tower...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
I need a power supply compatible with Cooler Master CAC-T05-UW. Features are ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 External 5.25'' drive bays, 2 External 3.5'' drive bay, 2 Internal...
The Cooler Master RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified Crossfire ready 80 PLUS certified modular active PFC.
Cooler Master eXtreme power RS550-PCARE3-US 550W ATX12V V2.3 SLI ready CrossFire ready power supply.
Two models that should fit with that tower. Cheers!
Aug 19, 2009 | Computers & Internet
Pc tower motherboard upgrade
you can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
May 27, 2009 | Compaq Presario 5000 PC Desktop
My computer wont play sounds it says i need a mixer or something, i formatted my computer yesterday and upon getting it working again i have had no sound... HELP?
Probably just need to update your drivers.  Check your device manager and if you have any yellow exclamations in the sound section.
May 02, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Gateway Hard drive replacement
Any PATA hardrive. Parallel also known as IDE. I would go for SEAGATE barracuda, simple, effective, and a 5 year warranty.
So, you will be looking for a 3.5 parallel hard drive. Check if your computer has a partition limit, ie, pre firewire 800 machintosh G4 towers cannot take single drives larger than 120 GB.
ATX is your motherboard form factor.
Keep me posted.
Oct 25, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Computers & Internet Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
