Question about Mitsubishi WT-46809 46" Rear Projection Television
Rainbow at the top and bottom of screen
Hi, I have a Mitsubishi 46 inch Big Screen HDTV (Model # WT-46809) that I just bought from someone. The display looks decent when viewing anything, but at the top and bottom of the screen there's a line that looks like a rainbow (red green, and blue I believe). You can somewhat notice it in the screen itself, but it's not too bad. It's just really noticeable on the top and bottom of the screeen where you can see the actual "rainbow" lines. Any ideas?
  • 3 more comments
  • Matt Youngblood
    Matt Youngblood Aug 23, 2006
    Any idea on how much this typically costs to have a technician fix it?
  • Matt Youngblood
    Matt Youngblood Aug 24, 2006
    Sorry to keep asking about this but I was reading that it might not be the IC's but I can possibly fix this issue using the advanced menu to calibrate the RGB. What is your opinion on this?
  • Matt Youngblood
    Also, I forgot to add to the above comment that the original owner said he kept large speakers right next to the tv (magnets possibly messing with the convergence), and when he move them away, the convergence got better but was still off.
  • Matt Youngblood
    Matt Youngblood Aug 28, 2006
    I was able to get into the advanced menu and set the convergence there. It's looking spiffy, now. It still needs to be profeessionally aligned, though. How much does that typically cost?
  • Anonymous Jan 10, 2009
    mitsubishi tv around 8 years old not vertically aligned..is there a way to fix manually?
  • 4 Answers
Thanks DJ,
I had the same problem with my TV, I had no electronic repair experience, and with your guide above was able to fix this on my own. However I did buy new IC convergence modules, but found out the the existing had a few cracked solder joints. I just resoldered them and works like new again.
Thanks Again
Posted on Aug 01, 2008
Stick in the micro wave
Posted on Jul 09, 2008
  • louis  khan
    louis khan Jul 09, 2008
    send it back tp the shop and get a new one
  • 4 Answers
I had the same problem. This is what I did: 1. Order the STK392-570 convergence IC and heat sink thermal transfer paste( I silicone based)..(make sure it is a reputable company so you don't risk getting bad components, I got them from an electronics supplier in MD) 2. UNPLUG YOUR TV AND ALL COMPONENTS!!!! 3. Remove the back cover and black plastic cover. (retain all parts) 4. remove the retaining bolts and screws on the black plastic tray (they are on the sides verticle mounted and front center as you are looking down on the tray.) This allows the tray to slide out like a keyboard on a computer desk. DONT PULL IT OUT YET!!!! 5. Just above the boards there is a shade board that slides out. Carefully pull it out. 6. You will have to unplug all cables ON THE BOARDS except for the RED ONES ON THE FAR RIGHT and provide tension relief for the cables by carefully unraveling them. The cables are marked on the connector and match to the markings on the board (I.E. KM, all connectors are marked with a two letter designation) Just disconnect the cables from all the boards and nothing elese. 7. Now carefully slide the tray about half way so you can see the contents of the entire center board. This is the board you need. Look in the back center of the board. There is a really large heat sink. The ICs are on the back side of this heat sink. They are held in place by a retaining bar that sandwiches the heat sink to the ICs. 8. There are some connectors on three sides of the board that are flat and white. CAREFULLY ....AND I MEAN CAREFULLY pull the left (as you are looking at board) ones up and disconnect from the center board. The ones on the right (I think they disconnect from the right board). 9. Unscrew the board from the plastic tray. There are a lot of them around the perimeter and center as well as the ones that hold the heat sink onto the board ( they also hold the board onto the tray.) You have to remove the "sandwich bar" (refer to 7)in order to get at the screws that hold the heat sink to board. (you have to unscrew them. 10. There is a box shaped cover on the left front part of this board that is screwed onto board and is also part of the retension to the plastic board, remove it to. (always remember to be careful when tugging, unscrewing, ect as it could result in breaking somthing) 11. There are black plastic tabs to the rear of the board. Unhook those and CAREFULLY lift and pivot the board forward and then up and out. 12. Now comes the easy part. You may have to pry the heat sink from the ICs carefully because of heat sink paste. Clean off the heat sink (dont use cleaner, just wipe the old grease off) 13. Use a good soldering iron (PACE, regulated, good desoldering iron) The temp just needs to be high enough to heat solder. 14. MAKE SURE YOU REMOVE THE CARD THAT WE TALKED ABOUT EARLIER that is in the front left of the board. You dont want it to break. Turn the board over so the chips are facing down. Take the desoldering tool and put it over the pins and in a circular motion until it heats the solder and push the sucker button. Do this to all of them that relate to the ICs. DONT KEEP IT TOO LONG ON BOARD. once you have done that to all pins, gentely tug on the chip wiggling it out. (carefully!!!!!) if you feel resistance desolder a little more. Make sure your desolder device is giving enough suction. 15. Now solder them back on and make sure you dont create any cold solder joints. This would be bad!!!! 16. Apply a decent amount of thermal heat transfer (grease, goo, ect) Make sure you do this or bad things will happen. You need this stuff. You can get it at radio shack. 17. Now put it back together and hurray you are done... Hope this helps... GOOD LUCK DJ
Posted on Jun 23, 2007
    President:
  • 3,130 Answers
Yep, you have a typical convergence IC problem.. if you knopw how to work on tv sets and know how to solder you can change then ICs and adjust the set. But if you dont, this is not a job for you to do . Find a tech to assist you in this repair. good Luck
Posted on Aug 23, 2006
  • Larry  Dillon
    Larry Dillon Aug 23, 2006
    For your set around 250 or 325, anything more and your getting ripped off.
SOURCE:
My Mitsubishi TV Model WT-46809 has the picture turn greenish pink after the TV has been on for a little while. What is the possible cause?
These sets did have one common issue where red, green, or blue would do what you are describing.
The set has 3 picture tubes and each has a small circuit board plugged to the bottom of it (bottom of the tubes faces down) and a ground would break loose or a part do the same.
I would examine the picture (see if you can take one and post it somewhere for me to see---picture will tell me a lot).
The ones with the ground broken usually show it more on the sides then in the middle of the screen.
Let me know all you can.
I am a top expert on this site.
Mar 19, 2012 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809
When you press the Volume Up/Down buttons does it show anything on the screen (like the level indicator bars...)?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
My mitsubishi model doesnt turn on i tried the menu and input and im getting the 2 2 blinks also pictiure noy looking good blurry bottom and top
I hope our talented expert would have given you helpful info in chat session about your tv problem, let me know if you need further help.
Thanks.
Sep 26, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi tv model wt 46809
Good Day, sam;
Sam it depends on "smudge".
If it's an oily type; then a mild soap, like dawn, on damp, warm soft cotton type cloth may remove it.
There are products found in most large best buy, circuit stores that sell a screen cleaner. It's sold in a small spay bottle, about 2-3 ounces. Always spray onto cloth NOT screen. Always wipe/clean with up & down strokes, NOT side to side or at an angle.
If the screen is smudged after attempts of trying to 'cleanning' a scratch, then only replacing the screen will fixya problem, cost will be in the range of $100.00-$250.00.
Good Luck, hope this was helpful, big IRISH.
Jul 15, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809 Big Screen
Good Day y'all;
When the is picture being intermittent and bowing then the most common problem is that the convergence circuit has failed or is failing. If you don't get fixed, the will go DOA soon.
Good Luck, big IRISH.
May 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
How do I replace Lamp in Mitsubishi big screen
You can get the service manual for your model for 12.99 at the following link. It has all the diagrams and procedures that you are looking for to service your set. They also provide free support with the service manual to help you with your repairs. They will also email the service manual to you if you return to the site and request it. Here is the link,
http://servicemanuals.vstore.ca/
Jan 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Wt 46809 Projection TV Mitzubishi
First check threads and do self diagnosis. Then live chat!
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
1,819 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
