Question about HP PSC 1110 All-In-One Thermal Printer
Paper got stuck i pulled it out wrong way now rollers wont pick up paper
PcExpert
  • 293 Answers
SOURCE: paper jam in 1120 hp printer
Hi there, Try printing again using heavier paper. Board types will likely push the torn papers out. Hope this solves your problem.
Posted on Sep 17, 2007
MUKHTAR
  • 2022 Answers
SOURCE: Printing Issue
switch off the printer and open up the cover and remove the toner and see is ther any paper is stuck inside. or try to print a single sheet from front panel. bye
Posted on Sep 22, 2007
  • 3 Answers
SOURCE: hp deskjet 9800 wont take paper
I think this could be solved by simply putting some more papers (at least more than 4 papers). if this doesn't work, check for any buttons on the sides od the printer... good luck
Posted on Jan 10, 2009
prnt master
  • 110 Answers
SOURCE: I had a paper jam, and pulled the paper through.
clean the dust from your cattridge and replaced it again.
Posted on Jul 30, 2009
tommya300
  • 724 Answers
SOURCE: wint feed rollers wont turn on
How did you get to the tranport rollers they are burried you are just looking at idler paper guides?
Posted on Jul 31, 2009
Hp3005 had a paper jam tray two, pulled out paper, now tray 1 keeps running pulling paper but doesnt print.
You have a pick up roller that needs replaced. If you pull the tray out, take a flashlight and look up into the printer. You will see a black roller. It probably is covered with white paper dust and slick looking. This needs replaced. That is all that is wrong.
Jan 03, 2014 | HP LaserJet P3005n Printer
Hi, i have a Brother MFC 7620N and 8 time out of 10 when i'm printing the paper get stuck and then i get this error obviously. My problem is that the paper always get stuck,do you know any idea...
Hi!
It is due to the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
May 31, 2011 | Brother Office Equipment & Supplies
Imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Jul 04, 2010 | Canon imageCLASS MF5530 All-In-One Laser...
Wont feed paper all the time
Is it modell from the picture?
Does the paper get stuck and wrinkled on one side? then it means that something is stucked in paper path - remove inks and turn the printer up side down and shake it, maybe it come out, if not use mirror and flashlight to deteck the foreign body
If the paper wont go inside at all, you have problem with pick up roller - most comon fault is that the roller holder breaks down and you do not have any pressure on paper, so no feed is possiblle
Hope that I helped
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Gestetner DSM635sp paper stuck error.The machine throws the error and then stops. there is no paper that is ever stuck. Thanks for your help.
Hello sir; There should have a paper stuck over the pick up roller that you can't see if you pull out the tray paper should be squeeze together. the solution way is replace paper pick-up roller.
Oct 01, 2009 | Gestetner Office Equipment & Supplies
Paper gets wrinkled in the paper guide and gets stuck
The "pick-off fingers" are supposed to be contacting the roller. They have tension springs that pull them down. One of yours have come off, or possibly the finger has broken off where the spring connects, so now the paper is running into it rather than crossing over it.
In the interest of saving a service call, and time. You can simply twist it off with a pair of pliers. Be careful not to bend any brackets/housings. It will run fine with 1 removed.
Eventually the fuser rollers will need to be replaced in your machine, and you can have a new finger installed if you want.
Please rate me. :)
Jun 17, 2009 | Sharp AR-207 Copier
1720 printer clicking and will not pick up paper
open the back "flap" up, and locate the pick up rollers. if the roller is jammed or stuck, just rotate it manually until it begins to pick up paper again
Apr 09, 2009 | Dell 1720dn Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
BizHub 450 Universal tray won't pick up paper
Sounds like either a loose drive connection or there is some trace piece of paper still left in the device.
BNe sure not to overload or UNDERload the tray as well.
Aug 25, 2008 | Konica Minolta bizhub C450P Laser Printer
The paper feed wont stop
the paper picking rollers i think r weak try cleaning the rollers n try it again.
thank u
May 26, 2008 | Canon SmartBase MP730 All-In-One InkJet...
HP PSC 1110 All-In-One Thermal Printer Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
