Question about Jenn-Air JMV8208A Microwave Oven
Jenn-air jmv9169bap vent fan will not turn off
Came home one day and fan was on. The only way to turn it off is to unplug the microwave. Is there a fix?
MicrowaveSvc
  • 9047 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
You can download the owner's manual and installation manual here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
SOURCE: No power on Jenn-Air JMC 7000 ADB Microwave
I have the same problem every time I use the oven for a long time and then use the micro.
Solution is simple, yet unbelieveable.
This is a toggle switch. It is located on TOP of the oven box.
It is almost impossible to reach...but once reached, all you have to do is push it and it resets the micro.
1-remove the "frame" around the micro.
2-pull the micro out (use 2 people) far enough so that you can reach your hand - or I use a wooden yardstick- to toggle the thing. It is VERY tiny.
Posted on Mar 24, 2008
SOURCE: JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Posted on Apr 24, 2009
  • 212 Answers
SOURCE: microwave exhaust door stuck in open and close cycle.
Depending on age You might need a new one. A repairman might be able to fix it.
Posted on May 24, 2009
Broken vent door/flap
Go to www.ebay.com Type: make and model of microwave, refine search to vent flap you might get lucky, if no luck, have a handyman come in and fashion a part.
May 09, 2012 | Jenn-Air JMV8186AA Microwave Oven
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
Apr 20, 2010 | Jenn-Air JMV8166B 950 Watts Convection /...
Top front vent keeps opening and closing while fan is running
You can find your owner's manual online here.
That should help you clarify & verify proper operation.
If you still need help, you can contact Jenn-Air (Maytag) customer service here.
May 20, 2008 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMV8000BAW
I always recommend that folks use the vent / hood fan anytime they're cooking with the stove.
Was it on at the time?
If not, moisture can certainly get into the works and cause problems or damage. If it dries out, it's fine but if not, it could cause damage.
Feb 15, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMV8208A  Microwave Oven Logo
27 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
