Question about Home
How do i purge a newly installed triton power shower
The motor runs but no water comes through
keemo68
  • 1263 Answers
SOURCE: Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
  • 659 Answers
SOURCE: my shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Posted on Apr 03, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: i have a triton ivory II shower, when the shower
Replace all or just your shower handle seat and washer on the shut off. Seems like a seal has gone bad and is not letting anything seat properly
Posted on Apr 18, 2009
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Ice maker runs continuosly but no water is in the cube tray
It could be the valve. If it does not let water in, it will try to make ice and none forms so the motor keeps turning waiting for ice to form.
If the motor is turning its fine. Concentrate on how the water reaches the tray, its probably not getting there.
Dec 22, 2013 | Whirlpool Refrigerators
Wash wipe only working on rear window no water comes out of frot. what can i do? 306 1998 model.
If there is no water coming out, and the reservoir is full, then check the plastic lines that run along the bottom most part of the hood (inside of hood near windshield) to ensure the line has not come loose anywhere, has any holes, or has broken.
Also, run the sprayer and hear for the motor running. If it is, then check the resevoir where the motor (should be) and make sure the wiring is not loose there as well. Last, check the sprayers themselves...they may be plugged - if so, if the reservoir is not full, put some hot tap water in it (empty if full, and fill with hot {not boiling} tap water. Then run the motor intermittently (no more than 15 seconds at a time), as you can burn up the motor if run for long periods of time. If they are clogged, this will help clear them out (consider using a dish soap as well such as Dawn (preferred) as it will also help break through the clogged areas.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 29, 2011 | Peugeot 405 Cars & Trucks
My washer has water leaking from motor
There is no way for water to leak from the motor . Check for water running down on the motor from the bottom of the tub. The seal may be bad water is comeing from somewhere else just have to find where it's comeing from. Hope this helps you.
May 16, 2011 | Whirlpool Cabrio WTW6600SBK
Water spay is really hot from the motor? cuts out after a short run. it gets that hot it steams. you can only get 500 meters then it cuts out? please help
Sounds like either your water pump is worn out, water intakes are clogged, or something is blocking the water passages in the motor. Just because you have water spray coming out from the motor, it does not mean that the motor is getting adequate cooling. In any case, you should take it to a motor repair shop and get it checked. If you keep running it hot you will probably ruin the motor.
Apr 28, 2010 | Boating
I have got Vauxahall Zafira wiper water doesn't come. Checked water is there. clean heads, undue the tube from heads. water doesn't come into the tube.
Underneath the water-tank a motor with water pump is fitted. Inside the pump there is free slideable metal cylinder, responsible for front and rear screens water supply. If some dirt is in water then it chokes this cylinder and as a result no water will be delivered although motor is running. I've cleaned the pump of my own car's screen washer and now its working. you need some time to invest in. Otherwise buy a new motor (costs around 20-30 quids from car parts shops).
Jan 07, 2010 | 2006 Peugeot 405
Where is pee hole on 1980 Mercury 4 HP 2cyl 2 stroke
Hey I just got the same motor and actually have the same exact concerns. Have you found any answers?
Aug 30, 2009 | Boating
Outboard motor overheating
Mate.The powerhead(engine block) is clogged.Don,t run it anymore untill its cleaned out or the motor will cook.Take the heads off 1st and see whats in the water jackets.It will probably be blocked.A build up of white 'gunk' is the main indicator.If thats the case,a complete cleanout is needed.Hope this helps
Jul 27, 2009 | Boating
Washers not working on ford focus
check the motor or hose probable clog. hope this help
Dec 17, 2008 | 2001 Ford Focus
Home Logo
22 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
