Question about Kenmore Washing Machines
I have a kenmore stakable washer and dryer combo. the model # 417.97862792. Neither the washer nor dryer turns on. Plug is in, circuit is good. suggestions?
It isn't getting power. Other things on the same circuit are working and plug is in wall. Is there a safety or a reset, or a fuse?
  • 537 Answers
SOURCE: Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Dec 07, 2007
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
  • 109 Answers
SOURCE: Kenmore model #417 40042990 Front Load Washer is
I would firstly take the back cover off and check the belt has not come off. Then check that the drain pump is not blocked.
Posted on Jun 16, 2009
  • 1122 Answers
SOURCE: kenmore model 417 94702300 stack washer dryer wont
bad lid switch-mike
Posted on Jul 30, 2009
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
How do I disable dryer on a Kenmore washer/dryer combo model number 417.99160110 only washer works
You have to start by removing the top first then remove he front console which allows you access to the dryer drum etc
Feb 04, 2016 | Kenmore Washing Machines
How do I replace the fuse in the dryer for stackable Kenmore model 417.98702891
This is an excellent source. Click on the link
http://www.repairclinic.com/Shop-For-Parts/a17b6d632276-x6d6f64656c/Model-Model-41798702891-Kenmore-Washer-Dryer-Combo-Parts
Jan 18, 2015 | Kenmore Washing Machines
Last night, the breaker tripped and we have lost power to the stove, hot water heater and the washer. We reset the breaker however, it dosnt seem like it is pushing enough power out for the stove, hot...
That means you have only one live wire running the whole house. If this happens the power sneaks through a 220 volt appliance and feeds the other half of the house but at reduced power (a brown out) This may damage appliances. Reset the main to the house. If it still isn't fixed call the electric company in your region to fix the wires feeding your house
Nov 26, 2013 | General Electric Electrical Supplies
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Is there a adapter that is made for this product,my wall socket in the laundry room is made for a 4 prong cord, but the machine is a three prong Frigidaire FEX831CS Top Load... stakable
Sorry there is no adapter for the plug. You need to change the cord from the dryer or change the plug in wall. You can get a parts at homedepot.
Nov 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washer/dryer combo (Model# 41792702200)
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
