Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Wont turn on
Just picked up my friends tv and seeing if i can get it to work so i can keep it for free. I plug it in and power it on, but all that happens is the indicator light turns on and the speakers hum, no picture. can you help?
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: TV on/off light keeps blinking red light/no sound or picture on screen
Here's a solution that I received from an TV expert in another website: "This sounds like a power supply problem. i have seen it several time on your model. i would not keep trying to turn it on it might damage something else in the tv. the reason it is shutting off is because the power supply is putting out too much voltage. a repair cost will range around 300-400. this is a great model and well worth a repair. here is a web site that might help you in finding a repairman.
http://www.nesda.com/locator/state_search.php." <-- $300-$400 is too much! But throwing away a 300lbs TV will cost a lot of $$$ for the towing and dumping too. I haven't decide what to do yet.
Posted on Dec 19, 2007
texasdan
  • 60 Answers
SOURCE: Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Posted on Sep 28, 2008
  • 927 Answers
SOURCE: wont come on
Howdy,
It sounds like the lamp has failed. It easy to replace, you cann find price and number on this site.
Good Day, big IRISH.
Posted on Dec 28, 2009
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
Tv wont turn on
tried to unplug the tv for a while to reset the power supply and then re plugged and turn it on let see if it will turn on. if still doesn't work and no power at all, at this time you will need to remove the back cover to access the power supply board, then look for a bad fuse or a burnt parts. replaced bad parts with the same value and rating.you can find replacement at www.digikey.com.
Dec 24, 2012 | Emerson LC195EM9 19 in. LCD TV
I was playing my PS3 and moved it from my tv upstairs to my tv downstairs. After plugging my PS3 in my tv downstairs, on which it had worked just 1 week previously, my tv picked up no signal from my PS3....
Try this.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 04, 2011 | Sony Playstation 3 (PS3) Console
I took my PS3 to a friends and we used an HDMI cable to hook it to his tv and when he brought it back to my house and now it wont work, i use the red ywllow and white audio/video plugs. why wont my...
hey, when you used the HDMI cable at your friends place, the PS3 display got set to 1080p. to bring it back to standard definition (red, white, yellow wire), follow these steps.
turn off you TV and PS3
turn on your TV
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
Now you should be able to see your PS3 menu on the TV.
Happy to help :)
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
I have a 50" lg tv wont turn on red light will
The tv power supply board is dying.That the board,where the power a/c acord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2011 | LG 42LC2D 42 in. LCD HDTV
Power went off and came back on last Friday and now tv wont turn back on
Have you got a stand by light on, or is tv dead totally.I would Check plug fuse if dead, My suspect would be power supply capacitors drying out (had this fault recently with friends tv) this caused tv to be working sometimes but eventually stuck on standby. Capacitors are cheap but not a job for the novice.
You could ask local tv shop for estimate
pete
Nov 08, 2010 | RCA L37WD12 37 in. LCD HDTV
Had the ps3 working fine, plugged it into another tv and nothing, the tv wont pick up the signal.. went to plug it back into the 1st tv and still nothing
Try resetting the display back to standard definition -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Wait for the PS3 display to reset
Hope this helps
Oct 26, 2010 | Sony Playstation 3 (PS3) Console
The picture wont come on
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Dec 02, 2009 | Toshiba 46H84 46" Rear Projection...
Tv wont turn on, i got it last april, it worked eversince,
First off, try a power drain:
Unplug the TV's power cable so it is not grounded to the house.  Then press and hold the TV's own power button in for a minute.  Plug the TV back in and see if it works. If it sill won't work, are there any visible LED lights you can see in the back of the TV?  You need to determine if the TV's power supply is shot or the TV's mainboard.  Service would likely be required if the TV still won't turn on.
Mar 24, 2009 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
