Question about Samsung TXE2546 25" TV
Samsung TXE2546 will not power up
My Samsung (TXE2546) will not power up.However it will flicker for a few seconds.It is plugged in (I tried several outlets) but will not work.
A few days ago it would work,but now it will not power up.I have had it for 11 years.I have not estimated how much it would cost,but if you can,please do. It is 25 inches.I know it isn't a cable problem because I tried to use my DVD player,my wii and my cable.
  • 23 Answers
 i think  there  should be  gone a output transister at  horizontal  stage.   if that tv is   21" or less  use  BU508F,D2499,1803DHI, OR = .......   if that tv is 25"  then use   D2508DF OR =.
if that proble is not above  then check the power suplly once  and check EHT(LOT) finally   .
Posted on Oct 26, 2008
My samsung LNT4061FX/XAA is flashing/blinking
There seems to be a common issue on several Samsung's where picture flickers/blinks. I first started seeing it a few months ago here and in the shop where I work.
Samsung is in some cases repairing it for free--seems the problem is on the power board (scene changes) can trigger it.
Solution in most cases is to REMOVE a jumper plug/or wire on the power board. A design flaw of some kind not anticipated by them.
A call to Samsung will resolve this either by them fixing for free or confirming this is the case---seen about 8 sets here where it did fix the set.
May 30, 2012 | Televison & Video
Can you change input on a samsung TXE2546 without remote?
There should be a button on the side/ It may be touch.
May 03, 2011 | Samsung TXE2546 25" TV
I have samsung txe2546. I just bought an auvio remote. Do you know what the code is?
Call the company and ask them or you can look at the side of the t.v. and see a tag with the code on the side! =)
Apr 16, 2011 | Samsung TXE2546 25" TV
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Samsung txe2546, how to adjust horizontal size. I went on the service mode but there is no adjustement for horizontal size. How can I adjust it, because the image is larger than the screen... Thank you...
Hello Laurent
This is pretty easy it's like when you adjust the imgae on your pc monitor, go to the menu then go to settings, select video or image, look for the option and just change it there.
Jul 08, 2009 | Samsung TXE2546 25" TV
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung TXE2546 25" TV Problem
Check for hot spots on circuit board = solder any/all bad connects + check for bad capacitors.......T
Oct 23, 2007 | Samsung TXE2546 25" TV
An oval-shaped rainbow-like colour pattern shows first, then, in a few minutes, picture starts to appear from the bottom and gradually extends towards the top thought never completely reach to top edge....
It May be due to one of several things. You could have some bad filter capacitors that are allowing electrical "noise" to disrupt the video, or there could be a bad solder connection or crack in the circuit board allowing a ground to "float", or there could be a problem in the Degaussing circuit, although that would be my last guess. I don't recall ever having that particular problem with any sets in my shop.
Dec 16, 2006 | Samsung TXE2546 25" TV
Televison & Video Logo
153 people viewed this question
Henry  Thomas
Henry Thomas
