Question about Garden
What is the gas/oil mixture ratio for Echo SRM 1501
  • 594 Answers
SOURCE: fuel mix and manual for Echo SRM 4000
Go to www.echo-usa.com/pdf/documentation/SRM40005000edi_110107.pdf
Posted on Mar 28, 2009
  • 246 Answers
SOURCE: I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
  • 10865 Answers
SOURCE: whats the recommended 2-stroke fuel/oil ratio for
50:1 is the ratio. the easiest way to do this is to get a small bottle of the 2 stroke oil premeasured for one gallon of gas.
Posted on Feb 25, 2010
Testimonial: "thanx"
Echo srm 225 manual
Smoke generally means you have too much oil to fuel ratio in your mix. Mix per manufacturer 50/1 exactly and try again.
Sep 02, 2014 | Garden
Echo SRM-230 trimmer stalls when you give it more gas. Can get more RPM with choke, but still not enough to use. Trimmer only has 20 hours on it.
empty the fuel tank and refill with the correct oil/ fuel mixture as too much oil blocks the jets Machines do not like any e- mix fuels as the jets are not set for the mix.
Jun 22, 2013 | Echo Garden
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
What is the gas/oil ratio for an Echo GT-160 AE?
Hi kth culberts...
US gallon Ratio: Ounces of oil per US gallon
50 to 1 mixture...1 pint of 2 cycle oil per 6 gallsons of gasoline..
Please take time to rate me
Jul 24, 2011 | Echo Garden
What is the fuel/oil mixture for my echo pb 250 blower
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
Jul 22, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
What fuel does my Echo pb500H use??? 2 stroke oil gas mixture????
2 stroke means that it is a gas mixture. 4 stroke means that there is no gas oil mixture.
Fuel is VERY flammable. Use extreme care when mixing, storing or handling, or serious personal injury may result.
Do not forget to rate the answer, Thank-you
Jan 02, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
I lost my manual. What is the gas to oil ratio?
Your manual can be found here:
http://www.echo-usa.com/documentation.asp?Model=PB-251&lang=E
Please download a copy, IPL too.
Page 21 - Fuel Oil Ratio- 50:1 (2.6 oz/ 1 gal)
A rich mixture often causes hard starting.
Oct 29, 2009 | ECHO, Inc. PB-251C Handheld Blower
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
480 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
