Question about Uniden 5.8GHz Dual Cordless Phone
How to register uniden tru9496 handset - Uniden 5.8GHz Dual Cordless Phone
SOURCE: How to clear all registrations from the base
You have to deregister all of the handsets and start over (as far as I can tell). Here's how to do it:
  • Unplug both the power and the phone line from the base.
  • Hold down the "delete message button while plugging the power back in
  • When you hear a long beep, all of the handsets are deregistered (not the short beep that just indicates the base station is powering up)
  • Reregister the handsets
Posted on Jul 21, 2008
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Posted on Oct 03, 2008
  • 98 Answers
SOURCE: Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
Posted on Nov 23, 2008
SOURCE: How to remove Uniden handset from base
The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
Posted on Jun 27, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
I have a tcx905s handset that will not register to my tru9496 base. Uniden claimed that 905s units will work with this base. However, they said that refurbished units will not work. Is this true?
Not sure about the refurbish issue...but have you tried to de-register the handset by holding down the end key and the # key, then placing on the main base unit to register with your system.
Sep 25, 2009 | Uniden TCX905 Cordless Accessory Handset...
I have extra handsets from a TRU9480 phone and
have it checked by ur near by customer service and ask them to connect
Aug 30, 2009 | Uniden TRU9496 Corded / Cordless Phone
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Uniden 5.8GHz Dual Cordless Phone Logo
78 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
