Question about Konica Minolta DiMAGE E50 Digital Camera
Format error with a 2 gb sd card
When inserting the 2 gb card the E50 gives the "format error" message
SOURCE: 2 GB SD CARD WON'T WORK IN MY Z3.
I managed to update the firmware and my Z3 works fine with a 2GB card in it.
Posted on Dec 12, 2007
beergut707
  • 79 Answers
SOURCE: Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Posted on Oct 21, 2008
SOURCE: Unable to use card
I have a Dimage z2 and had the same problem. I formatted the SD card using my PC - which did not correct the problem. Card still read "unable to use card". I finally formatted it using the camera and this solved the problem. The card I had problems with was SanDisk 256MB. Everything works great now.
Posted on Jun 30, 2009
SOURCE: I have bought 2 san disk 4 GB in 2 days and my
For $19.99 I will tell you how I fix the problem
Posted on Jul 10, 2009
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
Nov 10, 2010 | Sony Ericsson XPERIA X10 Cell Phone
I have a JVC 20 GB camcorder. Model GZ-MG2-1U. Before I tried to install an 8MB SD I selected on the menu to protect all. I turned the camera off, installed the SD card, turned the power on and then I...
There should not be anything to install when inserting an SD card, all you do is put the card in the card slot. If you tell it to format you have to go into the menu first and tell the camera which you are referring to the card or the harddrive. If you didnt change the setting to SD card when you did give it the format command than that is why your data was lost. If you are having an SD card error make sure that the little slide switch on the card is set as not to protect the card that will give the error sometimes. I hope this helps
Sep 15, 2010 | JVC Video Cameras
MY micro sd 2 gb wont show up
try inserting it on the other usb panel.
Sep 23, 2008 | SanDisk 2GB microSD Memory Card
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 50
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 50
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Konica Minolta DiMAGE E50 Digital Camera Logo
23 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
