Question about Hoover Vacuums
Replacing bulb hoover decade soft and light - Hoover Vacuums
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
My Hoover Soft and Light Supreme upright vacuum has a model #U4264-930. The last two numbers in serial # are 05. I have no manual and need to change a burned out light bulb. Need to know two things:...
http://www.vacshopusa.com/pdf/hu4253930.pdf Use this link to download a pdfd scehmatic for your model. This link is the site I got it from. http://www.vacshopusa.com/elite_%26_elite_ii.htm You may find more info there. Just from looking at the schematic, I would guess the bulb cover would pop off (carefully) and see what type of bulb it is. Remove it, take it with you to buy a replacement.
Nov 21, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Does the hoover runabout u427-930 have a filter? I replaced the belt and next to the light bulb was a square gray mat that looked like a filter covering a screen full of holes that looked like the motor...
From doing a search on the internet and hoovers website it looks as if this unit does not have a filter. Such as a hepa that needs to be replaced or that is washable. So i think you are safe and dont need to worry about it.
Aug 27, 2010 | Hoover Elite U5061-900 Bagged Upright...
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Replace belt - how do I get off the interior housing
Rather than try to explain this procedure by typing it, I'll give you a link to an online guide with pictures that show the procedure. You'll see two links on the page regarding belts , look at both and use the one that is closest to your model. Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Hoover Soft and Light Supreme U4266-930...
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
My girlfriend has a Hoover upright vacuum, Mdl. # U4645-930. I need a belt for the brush and a new bulb and am having trouble finding the correct part numbers so I can pick one up locally. Can you help?
I checked with Hoover and they said the part number for the belt is #38528040, for the bulb #27313101, and they also included a part number for something called an agitator #48414081. Not sure if this is required to replace one of the other parts. You might ask when ordering. To order, call 1-330-499-9499 or online at www.Hoover.com.
Dec 16, 2008 | Hoover Windtunnel Turbo Power U4645-930...
I want to change the light bulb on my hoover elite 600 upright vaccum. How easy is it to do and where do I start? Thanks! Brian
It should be fairly easy.
You will need a flat-edged screwdriver to pry up the white/opaque plastic diffuser that covers the light - the bulb is in a socket underneath it.
Pry up an edge of the diffuser with the screwdriver and you should be able to see that it's held on with 4 tabs - two on the top and two on the bottom. Push the tabs in on either the top or bottom and the cover should pop out easily.
Jul 19, 2008 | Hoover Vacuums
HOOVER VACUUMS
go to thehooverstore - this site lists a whole bunch of hoover machines, exploded diagrams and parts lists.
Aug 11, 2007 | Hoover Soft Light Supreme U4262-930 Bagged...
Vacuums Logo
24 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
