Question about Intuit QuickBooks: Pro 2005 for PC
Quickbooks pro 2005, Multi license
I have a quickbooks pro 2005 license for 3 computers, It seems I can only use it on two. It is set up on a network. I always get an error message when logging into one or another computer that the computer running, is running a different version, and I need to update, When I use the update feature it dosent seem to help, or if it does update, I lose the ability to work on one of the other computers. It seems one of the computers is always out of date. Why?
Thank you
    Champion:
  • Intuit Expert
  • 237 Answers
This can be a frustrating situation, and there may be more than one cause. Network permissions, user permissions, version and release of the QuickBooks program....all of these can play into this.
One suggestion would be to download the manual update from the QuickBooks support website. Save the file to a disk or a jump/flash drive, then run the update on all of the systems. You may have to open the task manager ( ctrl + alt+delete) go to the processes tab and end process on anything that begins QB.....
If they are all on the same release ( check by having the program open and do ctrl+1 on the keyboard, in the info screen it should have the version and an r number) the issues may lie with permissions, or even a stuck image file. Make sure the c: drive on the server, and the QuickNooks folders are fully shared, and that anypne logged into windows is a power user or higher.
Posted on Nov 17, 2008
I need license number and product number for quickbooks pro 2007
Check your paperwork. You should have received this information when you purchased Quickbooks.
Sep 09, 2014 | Intuit QuickBooks Pro 2007 Full Version...
Tip
Quickbooks Download Websites
IF you are using Intuit Quickbooks, Here's the download Websites:
Quickbooks Pro 2008 : Download
Quickbooks Premier 2008 : Download
Quickbooks Pro 2009 : Download
Quickbooks Premier 2009 : Download
Quickbooks Pro 2010 : Download
Quickbooks Premier 2010 : Download
Quickbooks Pro 2011 : Download
Quickbooks Premier 2011 : Download
Please make sure you know your License Numbers
Please rate if this helps..
Thanks!
on Mar 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
I need QuickBooks Pro and Premier Accountant License
Intuit QuickBooks Software Reseller 1 844 414 4868 Find an Intuit Reseller near you - Experts you can trust, Intuit Resellers ... Intuit and QuickBooks are registered trademarks of Intuit Inc
Apr 22, 2014 | Intuit QuickBooks Pro 2011 (License Only)
I need prodouct key for quickbooks 2014
Apr 17, 2014 | Intuit QuickBooks Pro 2011 (License Only)
I can not activate QuickBooks Pro 2006, Please help me.
Your only solution is to call Quickbooks help. Give them your license number and they will be able to walk you through how to re-activate your license.
Note: If you are attempting to install quickbooks on a second computer and you purchased a one user license, that will be the reason. They will make you pay for another license. You can only load Quickbooks single user license on one computer.
Hope this helps.
Aug 09, 2013 | Intuit QuickBooks® Pro 2006 Full Version...
Can't install quickbooks pro 2009
Sounds like you have the QuickBooks Database manager running or the Quick Connect feature still installed and/or turned on. Check and see if this is the problem by going to start and then programs and see if it says QuickBooks anywhere. If it does, slide over to see which of the two listed above are on. Then go to your control panel and uninstall the program. Double check to make sure the "quickbooks" catagorey disappears from your programs and then install the new version you wish to keep.
Jul 06, 2010 | Intuit QuickBooks Simple Start Edition...
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
I need a new license key for Quickbooks 2005,
If you had a license for it you still have a license for it. I think this program is too old for Intuit to offer support to you for it.
Dec 28, 2009 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks does not recognize license key after reinstall to repair. This is a multi user license.
Hello and thank you for using Fixya's services.
You will need to call Quickbooks customer service and they will re-activate the licnese for you. They do this so that it will keep the license safe from pirating or stealing.
Hope this helps!
Nov 19, 2009 | Intuit QuickBooks Pro 2007 Full Version...
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks: Pro 2005 for PC Logo
366 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
