Numark dm 950 mixer wont turn on. I over loaded it- is there a fix please?
Hi, I plugged in the wrong power supply (more than 500ma), there was a spark then after that, the mixer will not turn on with the correct 500ma supply. I read a bit about transistors in the power input getting fried but am pretty lost. Is this likely the problem and is there a replacement if so. I could not smell burning, nor can I see any scorch marks inside. I think the 500ma supply is fine, but have nothing to test it on. Would be much appreciated if someone will tell me a fix. Cheers, rich.
SOURCE: Power Supply burned up
Partstore .com has a board for this tv part #E7801-P02002 for $125.00 I ordered one my self.
Posted on Oct 02, 2008
SOURCE: HK206 speaker power supply
this is power adapter specs for HK206 found elsewhere
Made by: HON-KWANG
Plug in class 2 transformer
Model No: D12-10-1000
P/N: 66-000-118-01
INPUT: 120V 60Hz 25W
OUTPUT: 12VDC 1000mA
The polarity is negative (-) on the outside and positive (+) on the inside.
I will try RadioShack for this...
Posted on Oct 21, 2008
SOURCE: DMTECH DM-AV10
I would change the battey, if its not the battery i would place the media player on top
of some paper, stand back and admire your new paper weight.
Posted on Nov 03, 2008
djproaudio
  • 515 Answers
SOURCE: cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
  • 2920 Answers
SOURCE: Dishwasher burning smell now not working
it sounds like the motor may have burnt out
Posted on Jan 13, 2009
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
Kmx02 wont turn on
Make sure the plug for the power cord is the same polarity and DC or AC for the mixer. Also make sure the inner diameter is correct for the station power jack as well.
As long as power from the supply is correct and adequate, theother potential sources of problems can be a blown internal fuse, broken power jack circuit tracks/traces, bad solder joints, dirty switch contacts, some contact cleaner sprayed in the gap of the switch toggle and then flipped rapidly for a number of times might clean it up.
Feb 04, 2012 | Numark Industries Numark KMX02 Dual Deck...
Dear Sir/Madam I've just got Numark DM 1800 X Mixer. The problem is that they don't have the users manual to give to me, and I am not a hundred per cent sure how to conected to my amplifier. At...
You may find instructions on the numark web site. It is not a current model though.
There will be two mix out connectors, they go to your amplifiers.
Apr 08, 2017 | Audio Players & Recorders
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
No power.
sounds like your blew the first power stage, probally a fried power diode. is there a fuse you can replace? if not it will most probally need componet level troubleshooting/repair.
good luck!
jesse
May 05, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Wont turn on
This happened also to me before.
Just unplug the unit from power and reconnect. Switch on, and of you go.
By the way, there is a new firmware 1.13 available
www.numark.com/idj2
Regards
Jack.
Feb 28, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Tascam DM-24 Digital Mixer Problem
I purchased a used Tascam DM-24 mixer about 2 years ago, and it 's been running great. Just about 2 months, it frequently shut itself off with a message:
" Power Supply voltage (+5V) is too low for stable operation. Please restart DM-24".
Of course, many attempts of restarting the board, but it won't turn back on after several hours later, and only lasts about half a day work only. Very frustrating. Any idea I could get help or fixed? million thanks for suggestions. Brian
Dec 31, 2007 | Tascam Quantegy 120 Minute Digital Audio...
181 people viewed this question
 Grubhead
Grubhead
