Question about Canon ZR500 Mini DV Digital Camcorder
ZR500 Playback Issue
I have had my ZR500 camera for about 2 years now. Everything works fine with it, but ran into an issue.
I stopped using it for a while about 5 months ago. I was having a problem where I would upload the video to my computer and when I started to play it, the video would fast forward by itself for about 3-5 second, then play normally.
I recently began to use my camera again, but now when I record something and attempt to play it back, the screen shows only a blue image, which usually comes up when the part of the tape I am on does not have anything recorded on it.
During the time I did not use my camera, it was kept in a safe area and I'm sure that it did not fall at all. There seems to be an issue with whatever reads the tape. If anyone has a way to fix this, please tell me. Thank you,
  • Canon Master
  • 5,412 Answers
Clean the read write heads - if it has been stored with a tape in it, then the tape could have left a deposit on the heads.
Posted on Mar 15, 2017
SOURCE: No picture during playback
Thank you, I actually found the solution to this problem. We called Canon and they tried, but ultimately could only suggest that the unit needed to be cleaned. The gentleman we spoke to had not heard of this particular problem. But we decided we had nothing to lose, so we bought a Mini DV cleaner at Wal-Mart for less than $20 and it actually worked. Hopefully, this post will help someone else if they run across the same, apparently rare problem. Thank you, Angela
Posted on Jan 07, 2007
SOURCE: Canon ZR10 not displaying recorde image.
PLEASE USE VIDEO HEAD CLEANING CASSETTE & TRY ONCE AGAIN
Posted on Jan 10, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Tape Playback
Try cleaning the tape heads with a DV tape cleaner and see if that works.
Posted on Jul 07, 2008
SOURCE: pink or grey horizontal lines on video download or viewing
I have the same issue and have for over a year (haven't had the time to send it to Canon for a few weeks to analyze, but have cleaned it numerous times). But I can tell you that the problem is internittent and the recordings are fine. Eventually, don't know the remedy, but it will suddenly stop doing that and I can download fine, and watch on camera fine. When it does happen, I just keep recording. It never shows up permanently. I re-tyr downloading or viewing and about the 3rd or 3th time (let it sit for a few hours between) it is normal!
Posted on Aug 22, 2008
SOURCE: When ever the ZR500 is shaken, it turns off.
I think that when you shake it, the battery tends to move around and makes the camera lose power and when you stop shaking the battery settles and runs normally.
Posted on Oct 26, 2008
Can get mt canon zr500 camcorder to get reccognized on my laptop.. i have windows vista on my laptop...i'm trying to transfer my mini dv tapes on my canon zr500 to my computer..what do i have to do?
You have to use a firewire connection in order to transfer your videos. The cambera will not transfer the videos through the usb ports. There is no specific driver for Vista, and this isn't a driver issue. Use your firewire port and cable, and you should be fine.
Good luck,and hope this helps.
Mar 19, 2011 | Canon ZR500 Mini DV Digital Camcorder
I have a Canon ZR500 with no power and no light when trying to charge. Cannot eject the tape. I bought a second ZR500 on Ebay that is not giving me trouble with lines through the screen during playback. ...
1. This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
2. This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 16, 2010 | Canon ZR500 Mini DV Digital Camcorder
Camera won't turn on?
The power will not turn on. Solution
sp.gif sp.gif Follow this procedure to troubleshoot if the power will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  7. Attempt to turn on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required
http://esupport.sony.com/US/perl/contact-land.pl?mdl=DSCS730
Jul 24, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Canon ZR 50mc DV video bad picture
There is an issue with the video record/playback circuits. If you can playback previously recorded material then the problem lies in the record area.
Apr 01, 2017 | Canon ZR50MC Mini DV Digital Camcorder
IMovie and Canon ZR500 no image
I have a slightly different but related model of Canon camera. I have found that if you erroneously power it on in "camera" mode instead of "playback" mode, you get the symptoms you describe: you can control the camera with iMovie, but you can't get any video out of it. Make sure you have the power switch in "playback" position -- it's an easy mistake to make.
Nov 12, 2009 | Apple Power Mac G5 Desktop
Jumpy Video
I had the same problem while watching back thru Quicktime. Other post I have read people are having this issue on macs. Seems this is an Apple issue and not a Flip issue. When I play back thru windows Media Player everything is fine.
Aug 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Sound in camera not working
Have you found a solution to this problem? I'm having the same issue. Thanks.
millsj @ shaw. ca
Mar 29, 2009 | Panasonic SDR-H40 HDD Camcorder
Flash stopped working
Have you tried to reset the camera to its factory defaults to see if it is a setting that is causing the flash not to fire? To reset the camera go to the menu left arrow to reset - highlight yes and press ok. This will set the camera back to factory settings. See if the flash fires now. If it does then, good. If not, then it is a repair issue with the flash assembly internally in the camera.
Mar 23, 2009 | Olympus FE-210 Digital Camera
Canon zr500
The ZR500 has a firewire port that is best for tranferring video to your pc, so a firewire cable would be needed -- and you would need a firewire card in your pc to accept it. It might also have a USB port (don't have it in front of me right now). I've never used USB to transfer video, but I think it would work fine.
Jul 14, 2008 | Canon ZR500 Mini DV Digital Camcorder
Mar 15, 2008 | Canon ZR500 Mini DV Digital Camcorder
Canon ZR500 Mini DV Digital Camcorder Logo
102 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
