Question about Homelite Mighty Lite Lawn Trimmer
Homelite mighty lawn trimmer vt26
I took the handle apart and when putting it back together where does the spring go?
  • Anonymous Mar 20, 2014
    cant pull start it
    Scholar:
  • 76 Answers
Go to www.homelite.com then in the red area up top click on order parts, then click launch parts catalog, then scroll down and click agree and then you will need your model # then you will have a list of breakdowns that you can look at for your trimmer
Posted on Jan 05, 2009
Working on greasing up my Homelite UT 20760 grass trimmer. Took the throttle assembly part and having difficulty putting it back together. Can't find any diagrams and which hole to attach to on the...
Were you greasing the flex drive cable? That is really the only part requiring it unless you have a gear drive on the string head. Attatch the throttle cable onto the throttle plate hole which gives you the least amount of slack with the trigger off. That way, throttle response will be instant.You don't want but a little slack in that cable.
Jul 19, 2011 | Homelite Mighty Lite Lawn Trimmer
Pull start
Good chances is that the cord either got pulled to far out or the spring let go inside the cover that controls the rewind. It's not a big job...just remember how you took it apart www.nnyparts.com
Jun 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Load new line onto the mighty vt26 17" curved trimmer
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Jun 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
How do I take the UT20816 trimmer drive clutch off? Need to replace the spring for the starter cord rewind.
on my trimmer I took the motor off and there was a cable trans. with a silver-colored plate with 3 screws. I took them off and there was the starter cable and the spring (Caution it my pop out on you).
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Mar 25, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
358 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
