Question about Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
My sdm-x82 will not work. when i put the computer on, the computer will start but the screen will not come up but will be flashing messages, ' INPUT1 HD15' and 'NO INPUT SIGNAL. INPUT 2 . GO TO POWER SAVE'. so i am really confused, i pressed each button by the side ( menu, ok, input 1 and 2, eco) but it will not work.
Pls help, as i can't use my computer.
  • Sony Master
  • 5,568 Answers
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Posted on Oct 26, 2008
No input signal go to power save. monitor led gets yellow. black screen shows.
As most of the times the problem is caused by the computer, rather than the monitor itself, I'd advise you following my tips...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck,
Pelu.
Dec 08, 2010 | Sony SDM-S204 (Black) 20.1" LCD Monitor
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
LCD screen SDM-HS75P has a message on the center displayed all times.It says INFORMATION MODEL:SDM-HS75P SER.NO:1022769 MANUFACTURED:2005-18 and it stays on top of windows all time. How can I take this...
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Mar 04, 2010 | Sony (141857441) 15 in. Flat Panel LCD...
I noticed that my monitor has an additional port to connect another monitor to but for some reason its not recognizing the monitor
Is that a port for an additional monitor or is it simply an alternative method of connecting the monitor to the PC. My monitor has a vga input along with a dvi input and a hdmi input. These are all inputs not outputs.. Unless the port is specifically labeled as an additional monitor output, the chances are its an input.. You may have to use proprietry software to make any additional outputs available.. if the monitor is a Samsung, go to the samsung website and search for the monitor model. or read the manual..
Nov 02, 2009 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Green light "NO input signal go to power save" than white light at power
check the cable connecting from monitor to cpu is connected properly... try reconnecting it ... ur problem will be solved ...
Dec 03, 2007 | Sony SDM-HS73P 17" LCD Monitor
Out of focus/fuzzy
Your screen refresh rate may be too high for the monitor or one of the parts might be incompatible with windows try lowering your screen refresh rate. Or checking windows for a compatible driver for the chip or monitor.
Feb 09, 2007 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Sony DELUXEPRO SDM-X82 18.1" LCD Monitor Logo
465 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
