Question about Denon AVR1912
Connect a vcr to denon avr-1912 - Denon AVR1912
Duncan
  • 218 Answers
SOURCE: Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Posted on Nov 28, 2008
lynchms
  • 93 Answers
SOURCE: Cant Access System Setup on Denon AVR-588
Are you connected with video cables to a tv or "monitor" this is more than likely were the setup is visible for speaker configuration, input assignment etc, most denon receivers work this way so I would suspect you need to re-check the video connection until a set-up picture appears.
Posted on Feb 07, 2009
  • 11 Answers
SOURCE: I just hooked up my wii to my Denon AVR-2307CI
Most likely the VCR1 input in the Denon is set to a digital input, you will need to go into the setup for the VCR1 input and make sure that NONE is selected for the digital audio input.  Also - make sure you did not plug the Red/White audio cables from the Wii, in to the VCR OUT, instead of IN.
Posted on Apr 01, 2009
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Posted on Aug 23, 2009
  • 5 Answers
SOURCE: Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Posted on Mar 09, 2010
Can I connect a VCR to my Denon AVR-1912?
hi u have 5 sets of red and white audio sockets and 3 yellow picture sockets .u can use the dvd sockets or aux good luck
Dec 10, 2015 | Denon Audio Players & Recorders
Only left channel working on avr 1912
Sounds like a possible amp problem. Probably needs to go in for repairs.
Jan 07, 2013 | Denon Avr-1912 Home Theater Av Receiver...
Denon AVR-1912 firmware upgrade failed
I'm having the same problem, Denon has taken down the firmware upgrade for yours ( and mine) AVR-1912. My receiver is also stuck in the update fail loop. Supposedly they will have it back up, but I don't know the timeframe.
Lots of others are having the problem with the firmware upgrade. Go to
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/16380
and that should help you out, though I can't say how much. I've gone as far as resetting the microprocessor, but it keeps trying to update, and then fails...
Dec 12, 2012 | Denon AVR-1912 3D Ready A/V Receiver - 90...
My new denon 1912 avr loops during eimg update
It's happening to mine, did you fins a solution?
May 25, 2012 | Denon Audio Players & Recorders
AVR-1912 & no subwoofer
It sounds like the sub has an auto power mode, hence why it switches to red (off), so your system will not detect it. If there is any control to switch it on all the time do so and try it again. It must be green all the time during the test.
Jul 26, 2017 | Denon AVR-1912
DENON AVR-1912 PS3 ISSUE
You might just have a handshaking issue between your PS3 and your receiver. See if there are any firmware upgrades for your PS3, Receiver or both. This usually takes care of the problem. If not - your receiver has a 2 or 3 year MFG Warranty. Have it checked out or exchanged.
May 02, 2012 | Denon AVR1912
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
Need help connecting PS3 to my Denon AVR-3801
You could try sticking a vcr/dvd player in between the connections and using those input/outputs instead.
Dec 31, 2008 | Denon AVR-3801 Receiver
System: DENON AVR 3803 The TV is connected to the receiver, so both the audio and video components are fed through the receiver, I think. The image on the TV was present, but the TV/VCR button was pushed...
THERE ARE ONLY TWO WAYS THE TV SHOULD BE CONNECTED TO THE DENON,
1. MONITOR OUT OF THE DENON TO AN INPUT ON THE TV.
2. AUDIO OUT FROM THE TV TO AN INPUT ON THE DENON.
ALL YOU DEVICES CAN BE CONNECTED TO THE DENON IF #1 CONNECTION IS USED OR ALL DEVICES CONNECTED TO THE TV IF #2 IS USED
Nov 27, 2008 | Denon AVR-3803 Receiver
Denon AVR1912 Logo
95 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
