Computer is slow,need memory stick - Computers & Internet
  • 39 Answers
Do you want to purchase a memory stick?
try this website:
http://www.memorystore.com/
Posted on Oct 28, 2008
Memory Problem
bad sticks there,
BSOD screens?
finding good memory for such and old PC is not easy
did you buy them direct from Crucial or Kingston, ? or off fleabay.?
memory must match the MMC, chip, memory managers.
and the specs are not trivial. at all.
if it runs on the old sticks and not on the new,?
why wonder why, ( answer wrong sticks or bad sticks.)
#1 reason for this is memory
#2 is XP (and bad drivers to it)
buy from Crucial?
btw, why not test the sticks 1 by 1,
see which one is bad, and if all are identical (new set) then
all can be bad if using wrong sticks.
speed (too slow, faster is ok)
density rules, lots,... the older the CPU the worse this gets.
HP dropped all support on A-nnnnn PCs
so the pages showing all memory that work is gone now.
leaving only top memory makers are authorities no same.
I say ask them. in all cases this old PC.
Jul 15, 2017 | HP Pavilion a1330n (EL466AA) PC Desktop
I was given a compact presario m2105 notebook the has the sempron cpu. I would like to fix this up a bit and donate it to a young family who is without a computer. The laptop comes with 256 ram and was...
Hello
Try clearing c mos using jumper on mobo or pulling battery on mobo for a min.
Remove memory sticks.
Put battery back in,then memory sticks.
Then try notebook bootup.Set bios to either auto or optimzed setting.
Aug 29, 2011 | E-Machines 1024MB Memory Upgrade for...
I have a Precision 670 that I put two 512MB DDR CL3 ECC REG ram sticks in and it will start up but when it reboots, it beeps two slow, two fast, two slow and stops. lights on front turn: AC are...
The issue seems to be that your PC can not handle the supported memory. After review of your system specs on dell's website, I see that you're computer would require DDR2 Memory. This seems to be what is causing the beeping. Please check to ensure you are using the correct memory stick. I hope this has helped
Jul 05, 2011 | Dell Precision Workstation 670 PC Desktop
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Want to add another 512 stick memory to dell optiplex 270, it has one already. Will it speed up my computer
Hi yes it can speed up, first you need check in your manual what type of memory your pc is use, then buy stick with same specification witch is in otherwise it can slow your pc. Sometime it better replace it for one stick 1Gb if it help please rate it regards
Sep 08, 2010 | Dell Optiplex GX270
I purchased two 1GB pc2-4200 memory sticks and my Acerr Aspire T180 wont recognize it. It starts beeping and wont Boot. The reason I bought them was that my computer was running very slow after I re...
Hello there:
first off you will need to ensure that the memory that you have purchased is fully inserted in the slots next ensure that the memory is compatable with the motherboard that you have and your system
go to the manufactures web site of the computer and there will be a technical support option there with phone numbers to help you.
Also you may also want to swap slots with the memory sticks and see if this helps ok so please try these ideas. ok
best regards mike
Jul 31, 2009 | Acer Aspire™ T180 PC Desktop
Very slow also to increas memory
You need more memory. If you have windows xp you need at least 512 memory.
Jul 03, 2009 | Dell Dimension 2400 PC Desktop
Add Memory
it depends, you will want to check the type of memory first, and make sure you are purchasing the correct type. Also, if you have memory slots that are different colors, you will want to put the memory in two similar colors. also, i would advise buying a set of 2 1gb sticks of ram that are dual-channel capable, and removing the old memory. Otherwise the old stick of memory will significantly slow down the speed the new stick can run at. Memory is extremely cheap at newegg.com, you can get 2gb ddr2 ram for under $30.
Jan 20, 2009 | HP Pavilion a6000n (882780985018) PC...
I have just installed more memory to my computer and do not notice any difference in the speed of my computer
you may have installed memory that may not be compatible with your motherboard
do you know what type of mother board you have..
your memory must match in this categories
1. type (ddr, ddr2, sdram, simm, rimm)
2. speed (measured in mhz or sometimes given as a pcXXXX number)
3. cas number.
4. whether is ECC, parity, buffered, registered, non ecc
5. check your motherboard documentation to find exactly in what slot your new memory stick should go and which one should go first and which one should go second (ex. if you have dimm slots and you have 4 slots (2 pairs of different color) you may need to install one memory sticks like this: memory - empty - memory -empty
if one of the items that should be matched does not correspond your computer could work but it will work at the slower speed (ex. memory 1 (slow) + memory 2 (faster) = speed of memory 1
note: don't confuse memory capacity (1g, 512mb) with speed (333mhz, pc2700)... the best thing to do is to check the documentation of *********** board or even take the memory stick that you originally have and have the store looking for the memory that you need...
Sep 22, 2008 | Computers & Internet
Slow psp
hi! memory stick is problem in your play station! Remove the memory stick from the play station! And then you format the memory stick by use of computer! In memory stick you dont install fully! leave some memory space for it! Then you can use it!
thank you...........
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
David Payne
David Payne
