Question about RCA D52W19 52" Rear Projection Television
RCA 52 We have a 52" RCA TV and when it is turned on it continuously changes channels wothout the help of the remote. The remote does not stop this from happening. The remote does not work. It will pwer up and power off all by itself.
    Genius:
  • 1,030 Answers
The chances are you front keypad has malfunctioning i see this alot at the shop. if you can remove the front panel and remove the keypad cuircit board and turn it on with remote then it will definatly be the keyboard generally i suggest replaceing this cuircit l
Posted on Oct 29, 2008
The only control on the front of the tv that works is the on-off button. When the tv is turned on it continuously changes channels as if someone is holding down the up channel button on the remote.
I know the set well and would like to help---FIRST THING IS DISCONNECT THE POWER TO THE SET---a few minutes will be enough.
Plug set back and a good chance it will have returned to normal
If not let me know and let me know if on the front of the cabinet it has the "GUIDE PLUS" LOGO.
Dec 06, 2012 | RCA P52937 52" Rear Projection Television
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
My rca tv turns off and on by itself
Is there a prankster nearby thast has a remote tuned to your set? As a young lad I used to play this trick on my neighbors daughter.
You should also investigate whether it is timed.. that is has a regular interval or time that it does happen. It could be another appliancwe doing this A/C ,Security system or some other eklectronic device. The dog has the remote under the cushion?
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | RCA P52960 52" Rear Projection Television
Continues to channel surf wont stop on ant station
When i had the same issue, i used VCR or VCR Combo to set the channels,
May 14, 2009 | RCA R52WM24 52" HDTV Projection Television
When powered up-TV continually changes channels---RCA P52937SG MFG 2003
look at the control board circuit -are there and signs of heat damage if so replace board
May 02, 2009 | RCA P52937 52" Rear Projection Television
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
No response to the remote
check for coolant leak on microprocessor. Coolant leaks from the CRTs.
Jun 09, 2008 | RCA P52939 52" Rear Projection Television
Verify that you don't have a stuck channel up button on the panel. Next check the solder connections on the IR receiver (3 pins). Also check the +5 supply for excessive ripple. Any of these can cause odd behavior. Let me know how you make out.
Dan
May 02, 2008 | RCA P52937 52" Rear Projection Television
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
