Question about Dyson DC25 Animal Bagless Upright Vacuum
Dyson dc25 roller bar works but no suction - Dyson DC25 Animal Bagless Upright Vacuum
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC25. If the machine doesn't seem to be picking up as well as usual, this may be due to a blockage. The filters may also need a wash.
The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1148&product=DC25-ANIMAL
In normal use, the filters should be washed at least once every 3 months as shown in the video below. Use cold water without detergent, and allow at least 24 hours for them to dry completely before replacing them.
This should resolve the issue, but if you'd like any further assistance or advice, please give our Helpline a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Posted on Feb 23, 2012
chrispurs1
  • 372 Answers
SOURCE: dyson brush roller will not turn
Hi.
Your Dc14 will have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
Posted on Jan 11, 2009
  • 7 Answers
SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Posted on Apr 18, 2009
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
DysonInfo
  • 107 Answers
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Posted on Dec 20, 2010
SOURCE: My dyson dc25 pipe has lost suction..is something ...
We had the exact same issue. Turns out my wife had inadvertantly sucked up a magnet that was the same size ans the tube. Hold the tube up to a light source. If you cannot see any light, there is something stuck in it. To dislodge the item, stretch out a wire hanger and run it through the tube. It should lislodge the item. Dyson's are great but are very tempermental!
Posted on Jan 25, 2011
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    How to get suction to wand
    Pull up the wand fully and you should hear a click. If not, make sure that the hose is not kinked. See this video: http://www.dyson.co.uk/support/dc25/dc25-irsvsye/my-machine-is-not-working/jammed-wand-video to find out how to unkink the hose. hope this helps.
    Aug 14, 2014 | Dyson DC25 Multi Floor Upright Ball...
    Does a Dyson DC25 have two motors?
    yes roller motor and suction motor
    Aug 04, 2014 | Dyson DC25 Vacuum
    How do I reset my dyson dc25
    You may need a new belt if the brush bar motor is working properly. It could be the switch or brush bar motor if the motor does not run .
    Jul 06, 2014 | Dyson DC25 All Floors Bagless Upright...
    Where is the reset button on dyson dc25?
    I could be a switch, belt, brush bar motor or a wiring problem.
    Jun 19, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
    DC25 no suction at head?
    Hi there, it's Jack at Dyson.
    I'm not sure from your question how you're testing the suction at the cleaner head. For safety reasons we'd strongly advise against placing a hand underneath the cleaner head. This is not a good way of testing suction - the soleplate needs to form a close seal with the floor surface for high pick up. It's normal for the suction to feel stronger through the wand and through the cleaner head inlet as the suction is concentrated over a much smaller area.
    If you place the cleaner head on a sheet of newspaper, then run the machine with the brush bar turned off, you should see the newspaper sticks to the cleaner head, as it's able to seal with the soleplate.
    You might also like to take a look at our online Support guide, to make sure there's nothing blocking the machine which you may have missed: http://www.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
    If you have any further questions, it would be worth giving our freephone UK Helpline a call to run through some diagnostic checks with one of experts. You can reach us on 0800 298 0298 - we're on hand to help from 7am-10pm, 7 days a week, and calls are free from UK landlines.
    Best wishes,
    Jack
    May 21, 2013 | Dyson DC25 Vacuum
    Low suction
    We have one of these a few years old without the ball, pull out and see what suction is like with just the hose and the attachment for it, am I wrong and it (yours ) does not have the pull up and out hose? low suction is almost always a blockage in the air path between motor and cannister.
    Dec 13, 2012 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC 25 Ball - no power to motor
    Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
    Mar 14, 2010 | Dyson DC25 All Floors Bagless Upright...
    DC25 does not suction when in use? Any ideas as to how to fix it?I removed all hair that was in the rollers and still no suction.
    You probably have a blockage in the machine. Call the Dyson helpline to troubleshoot a blockage. They now what they're doing, they'll find a solution for the problem.
    Jun 26, 2009 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC25 Animal Bagless Upright Vacuum Logo
    52 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
