Question about Sharp 56DR650 56" Rear Projection HDTV
Picture fine for 10min.-then flickers(clicking sound)& then colors gone yellow
Our Sharp DLP TV is about 2 years old. Plays fine for about 10-20min. then Colors flash and a clicking noise comes from the back of the set. After it stops the colors are all washed out-looks like a tie-died Tshirt with splothes of clouds in the background. Is there any way to repair this? It doesn't seem to be a bulb problem(no warning errors)-any help is appreciated!
Looks like it's a color wheel problem-found a cleaning walkthru online, but it doesn't get rid of the loud hum form the CW motor. Also, it is thermal related-when the colors went out I placed a fan next to the color wheel and everything went back to normal. Several design flaws here and for $3000 these companies should do better-severe problems after a couple years is not acceptable.
Posted on Oct 27, 2008
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
My samsung dlp lost it's color and the picture is flickering and breaking up sound is fine It's also making a louder humming sound than usual. what is the problem
It sounds like the color wheel has failed and will need to be replaced. Color wheel will cost around $175.00-$200.00 plus 1-1.5 hours labor. You can call 1-800-samsung for the nearest service center.
Aug 06, 2010 | Samsung DLP HL-P5663W 56" TV
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
I have a VIZIO P50HDTV1QA DLP television and it
It sounds like the Color Wheel assembly has gone bad.Call a good TV Tech and explain the symptoms and he should be able to give you a ballpark estimate ($325)
Jul 29, 2009 | Televison & Video
Tv problems
Ckocanda, check to see if your picture is a little darker on one side than the other. Typical Sharp problem is the inverters. Tell that to your service guy when you take it in for repair.
Jun 11, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
TV turns off after a few seconds
it could be the bulb on the way out, they don't like to turn on if the inverter does not get a voltage use from the bulb, while trying to turn on the tv look at the vents for the bulb if you see it flicker on and of while trying to turn on the tv when it would be the bulb. when the tv is on and work hold a peace of paper over the vent not to cover it but to look at the bulb light if you see a flicker or bright and dim and repeats doing this then the bulb is warn out. if you hear clicking or scratching sounds this could be the inverter board on it way out.
Jul 03, 2017 | Samsung TX-R3080WH 30" TV
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Mitsubishi ws- 55807 clicking sound
My tv was working fine until now 8-9-08, it would not come on. The timer light comes on and goes off immediately.
Jul 20, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Sharp 56DR650 56" Rear Projection HDTV Logo
115 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
