Question about Maytag Washing Machines
How to replace water valve on maytag mtw5740tq0
How do you get to the water shutoff valve on back of maytag washer?
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
jsrock516
  • 5911 Answers
SOURCE: hot water fills but cold water does not in my
This is commonly caused by a water inlet valve with a bad solenoid. The valve can easily be replaced by following these steps:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Your washer may have the Maytag name, but it is manufactured by Whirlpool and has Whirlpool parts. The water inlet valve can be found at appliancepartspros.com for about $28. Just type in your model number and locate item 38 under the "Controls and Rear Panel Parts" heading. You may also try searspartsdirect.com, pcappliancerepair.com, or repairclinic.com to see if the part is carried for less.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Aug 04, 2009
jsrock516
  • 5911 Answers
SOURCE: How to disassemble Maytag Washer MTW5740TQ0
Your console has a retaining clip under the front corner on each side. You simply insert a putty knife under the console at the corner and push straight back, while pushing the console back with your other hand. The clip will release and the console will pop up. You can use the following link for reference (step 2 b.):
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
Your washer has the Maytag name, but is manufactured by Whirlpool and has Whirlpool parts, so these steps are for your washer. The link I provided explains how to access and remove the drive motor. If you are having problems with agitation and spin, you may have bad motor coupling. The next explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The steps are almost identical and the part number (if needed) is included.
You can view an excellent exploded view diagram of your washer at appliancepartspros.com. Section 4 shoes the console and retaining clips (item 3) that I'm talking about.
If your washer fills, then stops, or agitates then stops just before the rinse cycle, this problem is attributed to a lid switch malfunction.
I'm adding all these remarks, because you never stated what symptoms you were experiencing. If you have questions, please let me know. I hope you find this information helpful.
Posted on Aug 06, 2009
mastatech
  • 478 Answers
SOURCE: Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Posted on Jan 10, 2010
  • 662 Answers
SOURCE: Maytag Performa model mtw5740tq0: won't fill up with water
There is an exit hose behind your washer, it has to be maintained a particular height (approx 30inches from ground) before it goes into the standpipe in the wall. The gap in the pipe should not be a tight fit. Another thing that could have occurred is that one of the pipes underneath the washer has come loose; you just have to check these things out. But plug off the mains socket first!
Posted on Feb 10, 2010
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
No water going to ice maker and water dispenser in the door. replaced the "dual water inlet valve" 2 weeks ago and thought the problem was solved. No problems until yesterday when the same thing start
If your water line to the refridge has a shutoff where it is connected into a house water line, this shutoff can become plugged up. A lot of them have a needle type shutoff that when screwed in shuts the water off. This is where the house line gets punctured. When screwed out this little hole can become plugged up.. Screw shutoff in and out a couple of times and if you can disconnect line from this shutoff. Then open the shutoff and see if you can get water out of it. This may allow you to flush the hole and debris out of the shutoff. Then reconnect line and see if this helps. If it happens again you may want to replace the shutoff valve with a new one.
Dec 12, 2014 | Maytag Refrigerators
There is no power to the water inlet valve on maytag mtw5740tq0 washer what could the problem be
If you are not getting power then a relay on the main control board has gone bad...replace that.
heatman101
Aug 06, 2011 | Kitchen Ranges
Washer comes on but does not fill. After a few seconds, 'LO' appears in window. Water shutoff valves are on. Washer operated correctly yesterday.
check to see if the water inlet 3 way valve is working right. there are 3-110 volt coils that should have a white, brown and blue connector. the white one usually supplies voltage first (depending on mode used). try a hot only load and see if the hot come in.
Mar 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Feb 10, 2010 | Maytag MTW5700TQ Top Load Washer
Aug 06, 2009 | Washing Machines
Hot water fills but cold water does not in my maytag MTW5740TQ0 washer
Aug 04, 2009 | Washing Machines
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
