Question about Toshiba CZ32T31 TV
VCR not working with TV
Suddenly, when I click on the VCR, the picture on channel 3 freezes and there is no sound. If I change stations and come back to 3, the picture is blank. VCR and DVD has worked on this TV for years and VCR works on other TVs. All connections checked and channel on back of tv not changed. Apparently there is somesort of board in tv that has gone bad? Worth servicing? Thank you
  • 1 more comment
  • Ern Bartholomew Aug 23, 2006
    Let me be sure of your comment. When I said the picture freezes, its the picture that is on channel 3 before I turn the VCR on. The picture freezes and their is no sound. Normally I would get the picture from the channel that the VCR was set on. Then when pressing the run tape, the tape runs, but the channel 3 picture with no sound remains. Does your answer stand? If so, how do I greese the, what ever. Many thanks.
    As a test i have tried a second VCR with the TV and it also has the same conditions as the first.
    With all of the switching, I tried once last change. By passing the cable box going VCR to TV. That cured the problem. Apparently the box has some kind of fault which I can slove with the cable company. Your saying the TV was OK led to my trial and error replacement and solving the problem. Thank you very much.
    Novelist:
    Champion:
  • 275 Answers
What you state cannot be logical. If picture is freezing, then the VCR is at fault. But you state that the VCR works fine when played, and viewed on another TV. So, the only explanation I can think of is that there is some thing faulty with your VCR. Probably, when you play a tape, the picture freezes. This could be 'cos the Capstan motor of the VCR freezes. Common problem with aged VCRs. Just requires a spot of grease, and service. IT CANNOT BE THE TV AT FAULT!!!!
Posted on Aug 23, 2006
My jvc HR D170 ES vcr used to work fine when suddenly the picture ( snow ) is very bad but sound is ok ...tried to retune to my tv ...tried changing the rf at back ...tried tuning to my other tv and...
The vcr is fine. buy a cleaning tape. people say dry cleaner tapes wear out the heads, but it fixed my problem when my vcr only showed snow. but try a wet tape first. follow the instructions that came with the tape and run it a few times.
Jun 26, 2010 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Connecting my tv and vcr so i can use the vcr remote control
You can always push "03" on a universal remote programmed to work your TV. A better solution is to connect the devices properly. You shouldn't use the tuner inputs for a VCR/DVD player, or you will get a poorer picture and no stereo sound. See the instruction manual for your player and TV. Use a stereo audio/video cable to connect them and select the proper input. The instructions will hopefully clarify this.
Oct 16, 2007 | Philips Magnavox 27MS343S 27" TV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mar 30, 2007 | Mitsubishi CS-27309 27" TV
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Toshiba CZ32T31 TV Logo
162 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
