Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Sony KP-43HT20 Projection TV
Standby/timer red light is blinking 5 times and picture is very green and hazy. HELP!
  • VigAndrea Oct 26, 2008
    Please guide us further....
  • 10,594 Answers
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Posted on Oct 26, 2008
  • Shahid Electronics
    Shahid Electronics Oct 26, 2008
    Adjust / increase screen voltage of Red and Blue CRTs and try to maintain good Black and White picture. You should minimize Color control to zero to see B/W picture.
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
On our Sony KP-51WS510 projector television (with HD cable box) when we turn it on the screen goes green and the turns the cable box off and goes blank. Also I noticed the light on the front of the...
when it goes green, your green picture tube is shorting out, replaceing the green tube costs alot of money. these sony's had alot of bad tubes, the red and blue are probably going out too, it will cost alot to fix this, at least $500 even if you find good used picture tubes to put in it.
Sep 19, 2009 | Sony KP-51WS500 51" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
TV picture
its not the time for new tv the problem you r facing is not a major problem.
Check for multiple poor solder connection on the sweep/power supply board.
just need to balance the three colors red,green and blue that may help. remove the front covers and look for black module that have screw and focus controls just move little bit left or rightbe carefull because you can loos the picture
May 02, 2008 | Sony KP-53XBR45 53" Rear Projection...
Timer Standby light flashing No pitcher
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
No picture
does the red light give you a blinking code pause then code?
Sep 13, 2007 | Sony KP-53HS10 TV
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
178 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
