Question about GE WBSE2090A Top Load Washer
Washer won't fill with hot water
Hello. My washer will not fill when the dial is turned on to hot water. I hear a humming but does nothing. It will fill with warm and cold water when the dial is turned on to those buttons. What do you think it is and can I fix it?
Thanks so much. I appreciate it. ~Donna
  • 1,543 Answers
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Posted on Oct 26, 2008
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer fills, then just hums for about two minuts and shuts down
Hello
The hum sound is coming from the motor that is probably bad and needs replacement. Hope you understand...the washer fills with water which indicates that the control and the water inlet valve are both fine however, as after this you hear a hum sound it means that the motor is bad. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer seems to not cycle or take in any water. Is there a reset switch or button
If you hear a hum check the cold water inlet screen . If no hum check the valve or try hot water . If works replace fill valve.
Nov 04, 2010 | GE WBSR3140DW Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Will not run or drain
My wash machine doesn't open from the front but I am having problems with it not draining
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WBSE2090A Top Load Washer Logo
363 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
