Question about JVC Televison & Video
Getting started on a JVC LT-22DD3J
The television turns on but says no channels added, the remote doesn't seem to work and i think it needs tuning but im not sure how to do it?
fanicate
  • 60 Answers
SOURCE: Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Posted on Dec 10, 2008
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
SOURCE: JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Posted on Mar 29, 2009
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
  • 88 Answers
SOURCE: i need my television to do a channel search. I
You'll have to use the buttons located on the Tv. Should have a menu button and then you can use buttons like channel and volume up and down to interact with the menu. Input/video/source button typically acts as the enter key in a menu.
Posted on Jun 15, 2011
Can you tune in a JVC LT - 32DY8ZJ TV without a remote control?
As there is no Menu button on the front panel of the TV, you must have its remote control to tune it.
Nov 15, 2012 | JVC Televison & Video
The televisor it doesn't start with the remote control and the lateral buttons
Check to see that the remote control batteries are properly installed. They need to point in the direction indicated on the remote. Of course, the batteries need to be good! Perhaps the remote sensing eye on the TV is blocked. Be sure nothing is in front of the TV to block the sensing eye.
Sep 25, 2012 | JVC LT-46AM73 46 in. LCD HDTV
JVC tv stuck one channe
I would either call JVC to see if known issue or to inquire if set has a lockout feature that kills remote and all button features----other possible reason in main board with all micro functions has a problem.
Aug 27, 2012 | JVC LT-32P679 32 in. LCD TV
Cant unlock pin number jvc LT-32DR1BJ
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | JVC Televison & Video
How do I run setup without remote
you need the remote---an original remote.
Mar 25, 2012 | JVC LT-26WX84 26 in. LCD HDTV
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
How do you turn on the hdmi. my receiver does not reconize the hdmi. the cord is not bad it works when it is used to connect the receiver ad the stellite box.
If you turn the TV to an HD channel and get a black screen wth audio, then your reciever isn't HD capable. Check with service provider to make sure they got you an HD box.
Jan 03, 2010 | JVC LT-40X667 40 in. LCD Television
Remote control (i hope)
The IR sensor in the tv is probably weak, you could make a mountain out of a mole hill and get it replaced (using your friends receipt ^_^) but there's nothing to be done about the sensor.
Feb 05, 2009 | JVC LT-32P679 32 in. LCD TV
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
Adding a channel to TEAC television
Hi I had the same problem so I bought a cheap universal remote controller and tuned into this model.
Once it is done, press a number on the remote controller and you can start to tune manually.
I do not know about the solution for AV channel.
Feb 14, 2008 | Televison & Video
Televison & Video Logo
117 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
