Question about Frigidaire Washing Machines
FWTR445RFS1 Service Manual
Loud noise when spinning
2 Suggested Answers
  • 5 Answers
SOURCE: model # FWTR445RFS1. During the high speed spin
There is a shaft that goes through a bearing in the back of the outer tub which supports and turns the inner tub. It is connected to the outside edges of the inner tub by a "spider arm". The normal play for the inner tub should be smooth, even and firm. If you can get it to move one way more than another one of the arms of the spider may be cracked. It would require removing ans splitting open the outer tub to inspect the rear support of the inner one.
Posted on Dec 19, 2010
Entering test mode
1) try to go the instr. manual and go to the section troubleshooting they explain this . However if you do not have it download from .
www.manualslib.com
see this causes and fix it.God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch Assembly If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the
Drain Pump If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
transmission it may have to be replaced.
Sep 30, 2012 | Washing Machines
Loud banging clanking noise durings spins....
Might just be a shock absorbing rod has come loose from vibration. Remove the service panel and run the washer so you can see where the noise is coming from. Your tech sheet will be inside the service pane. I have the tech manual and ID parts photos with error codes for duet HERE. Note use your tech sheet for diagnosis not all are the same.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Model # FWTR445RFS1. During the high speed spin it just started making a loud thumping noise. Tried sever different loads and it does not seem to be a clothes imbalance. I also took off the back cover...
Dec 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Maytag neptune washer about 10 years old making a loud noise and leak on spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Above is your service and repair manual, download and use this manual to troubleshoot, and repair your unit.
May 17, 2010 | Washing Machines
MY WASHER IN FINAL SPIN STARTS BANGING OR SLAPINING LIKE A BAD BELT OR SHOCK, BUT THEY LOOK OK [ NO DAMAGE TO BELT / ADD, PREASURE ON TUB DOES NOT HELP ] NOISE IS ONLY ON HIGH SPEED OF FINAL SPIN FRIDG. #...
it could be 2 or 3 things wrong here 1 could be something as simple as an uneven load that would make the machine jump about and bang,it could also be the drum spider this is internal to the tub it holds the drum onto the drum shaft this could be broken or it could be one of the counter balance blocks as become lose all three would only really show when in high spin gd luck
Oct 29, 2009 | Frigidaire ATF6000ES Front Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
