Question about AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor
Can the amd athlon 4200 x2 proceesor be overclocked ? on the geforce6100pm-m2 motherboard
I have a geforce 6100pm-m2 with a athlon 4200 x2 proceesor and was thinking if you could overclock the proceesor and is it safe to do so
    Problem Solver:
  • 4 Answers
Not a good idea over clock it to much without the right cpu heat sink and faster fan will make it over heat and possably blow up it should work with 2.4 if not u need at least a 450 watt power supply with that card
Posted on Nov 02, 2008
AsRock Support > AlivenF6G-DVI Motherboard > Main Support page,
In the list on the left hand side, click on CPU Support List
The AMD Athlon 64 X2 5800+ CPU, (Processor), is part number ADA5800IAA5DO.
Operates Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz, has two L2 cache's of 512MegaByte, and uses the Socket AM2 CPU socket.
In the CPU Support :List it is not shown.
This is ONLY because the Athlon 64 X2 5800+, came out way after the CPU Support List was compiled. NOT because it isn't supported.
No, I have to amend that,
It's because AMD's lack of information, apparently, that AsRock didn't list it.
I don't see the voltage range listed anywhere. (To include AMD)
At any rate let's go with deductive reasoning, and see if this CPU is supported.
1) You can compare the Athlon 64 X2 5800+, to the other CPU's in the CPU Support List; that are comparable to it, and above it.
Don't even have to go too far.
Look at the ADA6000IAA6CZ, and the ADX6000IAA6CZ CPU's.
The two Athlon 64 X2 6000+ versions.
(Doesn't state that, just the above part numbers)
However I DO notice that the ADX requires BIOS version P2.00, and the ADA only requires BIOS version P1.60
(Since BIOS)
2) The motherboard chipset is an Nvidia GeForce 6100 and Nvidia nForce 430, Or Nvidia GeForce 6150SE and Nvidia nForce 430
Compatible? Yes.
May need the P2.00 BIOS update, if not already installed.
May 16, 2013 | Asrock Computers & Internet
How Do I unlock CPU cores with Bios on MCP61M-M3 motherboard?
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s Hyper Transport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
The BIOS changes it on it's own when add a dual core.
Here is the PDF file on this board. Chapter 2 explains the Bios.
Jul 03, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Will a amd athlon 3000+ fit in a asus km400
you need to find out what socket the amd athlon 3000 is and what the socket for the asus is go to amd's site and then the asus site they can help big time..=)
Nov 01, 2009 | Computers & Internet
Amd a64 x2 4 athlon 64 x2 dual core processor & Corsair xms2 2 gb
What we really need to know is the socket type for the AMD. AMD makes sockets 939, AM, AM2, AM2+, AM3, etc. will be the best friend you could ask for. I highly suggest their expert forums and chats as well, they'll help if someone here doesn't. But either way still need to know what socket that amd is. 5200, or 4200 or something like that is also more descriptive, thats how they ID their products. Mine is an AMD phenom II 920. Good proc.
Apr 19, 2009 | Computers & Internet
I have no idea in overclocking my PC
Download AMD Overdrive here
It is a powerful all-in-one overclocking, monitoring, and testing utility designed for users of motherboards with AMD 700-series chipsets.
Mar 11, 2009 | MSI 6600GT 128M VIVO/TV/DVI OVERCLOCKING...
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor Logo
189 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
