Question about Microsoft Windows 2000 Professional for PC
Can't get out of safe mode
My windows 2000 start screen is saying safe mode in every corner, my computer is extremely slow. I'm not that computer literate so please tell me how to fix this in layman computer terms. I have tried starting it in normal and no dice. This is driving me nuts please help!!!!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Safe mode is a mode used for fixing computers most of the time its usually initiated by holding down the F8 key on the boot up process. Make sure the key isn't sticking and its not automatically booting to that.
Posted on Oct 04, 2012
I have windows vista and my computer is in safe mode how do i get back into normal mode?
Posted on Jan 12, 2009
  • 61 Answers
While booting ur system press F8 initially when system turned on you will get booting options .Select Normal and Enter you can able to boot in normal mode.
Posted on Oct 29, 2008
How do I get my computer of of safe mode
in safe mode, click the start button and then "run"
In the "run" window type: msconfig
and then hit enter or ok. You should now see a "system configuration" screen, at the top are several tabs and one should be labeled "Boot"
Near the bottom of the window should be several box's you can check or un-check, most likely your safe boot option is checked.
So un-check safe boot (don't think anything should have check marks in them) and then hit OK. Windows should then ask you if you want to restart.
Once restarted you should be in normal windows :)
Sep 30, 2014 | Microsoft XP Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How do you put the computer in safe mode on a HP pavillion?
If I remember correctly, for Windows XP:
Click on 'Start' at the bottom left of your screen
Click on 'Run' - should be on the right side of the Start menu towards the bottom.
A box will appear at the bottom of the 'Start' menu. Enter "msconfig" (without quotation marks), and press the Return/Enter Key.
A new window will open with several tabs. Click on the BOOT.INI tab to open that, and click in the square box first on list by /SAFEBOOT. There are three variants of safe mode. For now, choose 'Minimal' (click in the circle by that word). Now move to bottom right of the MSCONFIG window and click on the 'OK' button. Now the window will close, but next time you Restart/Start your computer it will be in Safe Mode (font will different, and it will say 'Safe Mode' at the four corners of the screen).
12.April.2014
Aug 30, 2012 | HP Pavillion s7420n PC Desktop
I have the same problem with my computer not shutting down, it just stays on, even all night saying it is shutting down (blue screen). I have a laptop HP Pavilion Entertainment Notebook PC w/XP. It is also...
This sounds like a hard drive error. You should deliver it to a professional, or test it by yourself it that is possible. If you have some kind of warranty for your computer, you should deliver it were you bought it.
Nov 14, 2011 | HP Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
When I boot up my laptop, it asks me 4 options. Start windows normally, safe mode, safe mode with command prompt, and safe mode with network support. It doesn't matter which one I pick, but when the laptop...
To start your computer normally you must choose either of that options but the only thing you must choose is the start windows normally so that all the settings from the previous working settings will be applied in your windows start up.
Dec 25, 2010 | Toshiba Satellite L45-S7423 Notebook
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Can't get computer out of safe mode
From Windows Safe Mode click Start / Shutdown and restart the computer. This should start the computer automatically back into Normal Mode.
Note: Many users believe that they are still in Safe Mode because the colors or video may not look correct. Unless in the corners of the screen it says "Safe Mode", you are not in Safe Mode.
If you are rebooting the computer and it is rebooting back into Safe Mode (it does say "Safe Mode" in each of the corners), it is likely another problem exists with Windows preventing it from loading into Normal Windows.
If this does not work try: http://www.computerhope.com/basic.htm
Dec 30, 2009 | Compaq Presario Notebook
HP Pavilion a420n
You almost certainly have a virus. If you can't even get into safe mode the easiest way to fix it is remove the hard drive and back up any files on it with a different computer, then re-install Windows on the original drive.
You can try booting from your Windows XP installation disk and using the recovery console there to repair your installation. That's not too hard and I would say works 30% of the time.
Jan 01, 2009 | HP Pavilion a420n PC Desktop
Microsoft Windows 2000 Professional for PC Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
