Question about Seiko Watches
Zoo york watch shorten link - Seiko Watches
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: How do I shorten the watch band?
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 28, 2009
  • 51 Answers
SOURCE: shorten watchband
You can find here step-by-step instructions with pictures:
How to shorten a metal watchband
It is for a casio watch, but the watchband has the same principle with "arrows" on the links.
Posted on Sep 13, 2008
SOURCE: removing links to shorten watch
I just removed links from one of the white stag watches today. The answer is in the link below.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Friction pins are used to hold the links together. I used a jeweler's screwdriver and a small hammer to tap them out in the direction of the arrow. I put them back in the same way.
Posted on Apr 19, 2009
SOURCE: I need to shorten the metal link watch band of my
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Posted on Jan 02, 2010
Zoo York watch
Try Googling (zoo York)(model)(manual) without parens.
May 28, 2017 | Watches
How to set the analog clock on a zoo york watch.
find the thing that moves the hands
Sep 23, 2016 | The Watches
Trying to set watch
I'm going to assume that you have the ZY1006 model. Setting instructions can be found at :-
http://www.genevawatchgroup.com/wp-content/uploads/2012/12/Zoo-York-ZY1005_ZY1031.pdf
Jun 02, 2016 | Watches
Need to set time for zooyork zy1035/s60-12
They all work pretty much the same, once you get use to setup you can figure it out on any. Here is a link below
http://www.genevawatchgroup.com/wp-content/uploads/2012/12/Zoo-York-Digital-Watch-Instruction-1.pdf
Jan 30, 2015 | Watches
Alarm won't turn off on Zoo York watch.
I have a different model but this solution came up in Google and it didn't work. On mine, I tried the following: press MODE. It will show the alarm time. Then press ST/SP a few times until the little alarm icon does not show on the alarm face. If you press RESET instead of ST/SP, it will start blinking and will want you to change the alarm time instead.
Mar 14, 2012 | Watches
I don't have an instruction manual for Zoo York
have a zoo york watch and I can't understand the directions
Aug 10, 2011 | Watches
Watches Logo
1,907 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
