YAMAHA DSP-AX650 SE 7.1 AMP AMPLIFIER instructions
  • 319 Answers
SOURCE: AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Posted on Apr 29, 2008
Duncan
  • 218 Answers
SOURCE: Puchased A Yamaha DSP-A1092 Amp from Auction turns off
I doubt it. Sounds like it is going into protection due to bad output transistors or some such. Time for a trip to the repair shop it sounds like.
Posted on Nov 14, 2008
  • 211 Answers
SOURCE: HOW TO INSTALL THE 15 BAND EQUALIZER TO THIS
I dont know this amplifier, but if there's a tape-monitor button, you can insert the eq on the tape in- and output.
Kind regards,
Gerard
Posted on Jul 07, 2009
tbreeze47
  • 3083 Answers
SOURCE: yamaha dsp-a492 amp keeps switching
Amplifiers have protection circuits that sense current overloads, and especially internal faults, and theyt shut themselves down to prevent further damage to the unit, until it can be troubleshot and fixed. They're designed to allow minimum damage to the unit, and the cause of the overload must be found and fixed by troubleshooting the unit systematically. Sometimes you can get lucky and ohm out a suspected power transistor or IC regulator and replace it successfully, but most of the time a scope is required.
Take it to an audio repair shop and get an estimate first, but know that they do charge by the hour, and it can get a bit expensive.
I noticed this same problem was posted in a couple of forums on the net, but they never got a solution or followed up, so service is in order.
Good luck, and hope this helps.
Posted on Oct 30, 2010
SOURCE: I'm looking for instruction manual for my amp
The manual is available to download on the Yahama site (usa.yamaha.com). Click on the "support" tab.
Posted on Jan 22, 2011
Where do you hook up outside speakers
'Outside' is not a choice on the unit.
If you want to drive a separate amplifier with speakers somewhere you could replace the Main Channel Pre-Out jumpers with an RCA-Y-adapter and slave the second amp and speakers to this unit's volume controls; or you could attach a second amplifier to either TAPE REC OUT pair and the external amp and speakers would have independent control of volume locally.
Jul 03, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
Dear Sir Good morning Is the DSPA-3090 a receiver(integreted tuner )? Thank you ganesh
http://usa.yamaha.com/products/audio-visual/hifi-components/amps/dsp-a3090_black__u/?mode=model
No.
Apr 19, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
I'm looking for instruction manual for my amp Yamaha DSP A-1000 THANK YOU FOR YOUR HELP
Jan 19, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Amp DSP A-3090 Power/function/Remote
These issues can only be fixed by an audio-tech.
Do a websearch around your area for a repair person
Sep 30, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha DSP-A3090
what card is that? the whole volume control assembly you mean? what is wrong with it my friend? only yamaha can provide you with that part. maybe you need the volume control only. that one also only from yamaha.
Mar 30, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
50 people viewed this question
 Grubhead
Grubhead
