Question about Acer Aspire 5610-4648 Notebook
Acer Aspire 5050/3050 Series
I recently replaced my hard drive and now need to relaod the operating system but dont know how to do this? Does it need the operating system that came with it (lost) or can I use the one from my gateway??
  • 903 Answers
I don't know what you mean by the gateway? if you mean restore disks then probably not because it is a new harddrive. You will need to install a new version of what ever windows it is that you require.
Posted on Oct 26, 2008
How to reset acer aspire 5538 hard drive password
Hello Peggy
Bad news, if you forgot your hard disk password there is no way to help, just buy a new one, and recover all your operating system again.
Carl
sorry, but at least its my opinion
Feb 02, 2016 | Acer Genuine OEM Aspire 5536, 5536G, 5538,...
Hard disk was replaced no reference point
if your previous hard drive can be read externally you need to use the recovery files due to the fact that your operating system is in the old drive and must be installed into the new drive or get a fresh operating system install.
Nov 11, 2014 | Lifetime Acer Aspire 5741 Replacement...
How to fix a missing operating system on acer aspire 4920 series laptop
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
May 13, 2014 | Acer Aspire Computers & Internet
I am using acer aspire series laptop that after an year of use bacame very slow. The entire operating system responds so slowly that often it shows the messege "not responding". My laptop came with pr
I would consider replacing mccafe antivirus because really slows the system down. Go to www.download.com Type: malwarebytes anti-malware and ccleaner, run malwarebytes first and do a full scan, followed by ccleaner, and finally defrag the hard drive. This should help speed up your system.
May 15, 2012 | Acer Computers & Internet
To whom it may concern. im looking to reboot my acer 6935 but i dont know what way to do it, i dont have the recovery disc. could you please help. thanking you.. brian o' connell
This procedure will work usually unless there has been an alterations to the originally installed OS on the Acer. On recent Acer computers they have a hidden volume on the disk labeled PQService.
This volume is for restoring the computer to the factory settings in same condition as purchased new. It will erase everything currently on the main hard drive.
Step 1: Backup everything that is important to you, on a disk or separate hard drive.
This includes any documents, pictures and application installers.
Step 2: Reboot the system and press ALT-F10 during the POST to start the Acer eRecovery Management and reinstall the operating system.
Step 3: Select Restore system to factory default.
Step 4: The wizard will lead you through formatting the designated drive and installing the operating system from the computer hard drive to the designated drive.
Jul 20, 2011 | Acer Computers & Internet
My Acer Aspire One has been ok until recently when i turned it on and the screen runs windows Xp several times. It turns off and on several times without ceasing, and the only thing I see is the Windows XP...
Hi,Your operating system is corrupt,probably as a result of an infection or as a result of the Hard Disk failure.so i'll advise you take out the hard drive,back-up your files if any and format your system,then re-install operating system.
Jan 02, 2011 | Acer Aspire 5610-4648 Notebook
Windows comes up showing acer then it goes back off it dont come back on the window goes black.until i turn it back on
Put a bootable CD into the drive and change the boot order in setup to try to boot from the CD first. If it boots, then you know the problem is with the hard drive or with the operating system on the hard drive. Take the hard drive out and slave it to a working computer. Make sure it is the same operating system. You can get an adapter for the cable connection from your local computer store for about $15.00. If you can read the drive on the other computer, then you know the problem is the operating system. Burn all your files to CD or DVD while you have it slaved to the other computer then put the hard drive back into your laptop and then run your recovery discs. After you reinstall the operating system you can reload all your files. If you cannot read the drive when you have it slaved to the other computer, then the drive is toast and needs to be replaced. I hope you have backed up your files regularly.
Dec 17, 2010 | Acer Aspire 5100 Notebook
Blue screen
This seems to be an Operating system issue , best way to resolve this is by Re-Installing the Operating system which will wipe everything in the laptop Hard disc, At the Acer splash screen, you can press Alt and F10 to bring up a DOS style version of eRecovery. The unit is able to reload Windows from this mode faster then from CD. If the hard drive is replaced the system loses its eRecovery features. These features are on the hard drive and cannot be reinstalled
Jul 13, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5050 won't boot up
ooh...no operating system. not good. ok..can you boot from CD? if that works, and it asks you to reformat the hard drive, STOP. Take the hard drive out, and then GENTLY reinstall. Maybe that will work. HD's can fail on laptops, just by a series of vibrations or shocks to the case.
got backup for your Acer?
Feb 16, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 5610-4648 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
