Question about Samsung Refrigerators
Fridge door hatch
The latch on the drinks hatch o my Samsung fridge freezer is broken and whilst the door still closes and the fridge functions properly I would like to replace the catch rather than the entire fridge.
IB4G2008
  • 3587 Answers
SOURCE: we have Samsung side by
hmmm....can you check the hose to make sure it's not crimped, and that the source of water is still connected and 'on'?
Posted on May 23, 2008
SOURCE: Maytag Plus side-by-side freezer constantly needing to be defrosted
Water is collecting on the bottom of the freezer and freezes then it becomes so much it starts to leak out side the freezer door. get about 1/4" thick. Is there a leak some where? Take about 2 days to form.
Posted on Jun 18, 2009
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
Samsung Fridge Freezer Door Handle Came Off - No screws is it vacuum based.
The screws are in the holes on the side. You will need an Allen wrench to tighten them
Sep 29, 2015 | Samsung RSA1SHPN American Platinum Inox...
My Samsung Cool' n Cool Fridge Freezer it wont stop beeping. The doors are both shut and the appliance is switched on. I have accidently broken the little plastic mechanisim that opens and closes upon...
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
Aug 31, 2011 | Refrigerators
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
Why my fridge keeps icing up while the freezer is ok
generally speaking the fridge is not frost free whilst the freezer is.you can reduce the amount of frost by checking door seals are tight to frame/drains are clean and free of s..t and ensuring food/drink is covered to cut down on condensation.if you have a seperate thermostat set it to +5C.
Aug 25, 2010 | Refrigerators
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
How to unlock a broken ford windstar rear door
You will need to remove the hatch panel, and release it manually. It is a pain in the **** with the hatch closed, but it can be done.
Jun 05, 2009 | 1995 Oldsmobile Silhouette
Door ajar light stays on
go to your local parts store and buy a can of PB BLASTER lubricant then open each door and spray the latch assembley really good then close and open the door 10 to 15 times. do this with each door. the door ajar light switch is located in the door latch assembley and cannot be seen so soak the latch assembleys really good so lube reaches the switch. these switches sometimes get stuck but this usually frees up the switch
Mar 25, 2009 | 2003 Mercury Mountaineer
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
