Question about Panasonic Technics SL-DZ1200 Turntable
LP Turntable Rotation speed varies. Was in storage for years. New belt. Product SL-20 not listed. Entered closest match.
  • I have one with the same problem, but nevertheless if yours is up for grabbs I'm interested.
  • 104 Answers
The platter must be able to spin freely without a belt installed as shown in this video
http://www.archive.org/details/Turntable_Belt_Installation
that would be one likely cause presuming you have the correct new belt that is.
Posted on Feb 12, 2009
How can I record from the turntable on my Ford Mustang Ion to my Ipod nano?
Advertising says;
4-in-1 retro music center with turntable, radio, USB and aux input
  • 3-speed belt-drive turntable plays all your records
  • Records your albums onto USB flash drive
  • Sensitive FM tuner with speedometer look
  • Built-in speakers and headphone jack for private listening; Auxiliary input for connecting and playing other devices
  • So record to USB, put the USB into the computer and transfer it using Windows File Explorer, using right click, drag, copy here, so a file location on the hard drive like 'My Music'. Then connect your iPod and transfer it. You may have to buy the 'iTunes Match Package' to allow you to use music not purchased from Apply. It is $24 a year.
    Amazon com Ion Audio Mustang LP Ford 4 in 1 Classic Car Styled Music...
    Apple Music vs iTunes Match What the difference
    Dec 27, 2017 | The Audio Players & Recorders
    I have a technics slbd20d for about 6 yrs. teh speed started to fluctuate, so i replaced the belt, with an orginal replacement from panasonic, and one from lp gear to match my turntable. but the speed is...
    u mean the recor speeds and slows down? if its an older turntable there is some play in the bpms thats why most people get direct drive. my sugguestion is to look it over and tinker w things but dont break it. im sure you can find a manual online
    May 05, 2011 | Technics SL-BD20D Turntable
    Speed varying
    Chances are the belt is slipping. Therefore ridding up and down, causing the speed problems.
    Nov 25, 2009 | Technics SL-BD22 Turntable
    Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
    Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
    http://www.turntablebasics.com/belts/technics.html
    Oct 28, 2009 | Technics SL-1210 Turntable
    New cartridge for Technics SL -BD22D
    the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
    To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
    http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
    Feb 03, 2009 | Panasonic Technics SL-BD22D Turntable
    Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
    hello
    You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
    Oct 09, 2008 | Technics SL-1210 Turntable
    Sudden pitch change.
    There is a speed control IC inside this unit that could be defective or the speed detect sensors could be faulty. WIthout seeing the actual machine it is hard to tell. This one is a direct drive if memory serves me correctly, so you should not have this kind of drift. With the unit only a year old, I would not expect a motor problem either. Can you tell if the drift is toward higher speed or lower? Or does it vary?
    Dan
    Jul 24, 2008 | Technics SL-1210 Turntable
    Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
    Howdy Ivy:
    An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
    http://www.servicemanuals.net/
    for about $16.
    Paul H.
    May 03, 2008 | Technics SL-1210 Turntable
    All my vinyl sounds warped on turntable
    Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
    The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
    Feb 17, 2008 | Technics SL-1210 Turntable
    Panasonic Technics SL-DZ1200 Turntable Logo
    229 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
