Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model gss201epaww, getting ice but no water.
Ice maker works but the water dispenser will not, the motor hum’s but no water.
catriver
  • 878 Answers
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Posted on Jul 24, 2006
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser not dispensing ice or water
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Jun 24, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool side by side GS6NBEXRS01
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Aug 28, 2007 | Whirlpool GS6NBEXR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
29 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
