Both my hdmi outputs are not working on my lg 42ly95
Both my hdmi outputs dont work on my lg 42ly95 tv
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
jojack2k5
  • 34 Answers
SOURCE: HDMI Cable dosn't work? AVI only. WHY?
chk factory outgoing settings in service menu
Posted on Apr 29, 2009
satavlad
  • 405 Answers
SOURCE: HDMI PORTS NOT WORKING
Try visually inspecting HDMI’s that are not working. Occasionally, pins on HDMI connectors are getting bent or pushed-in. If you can spot the damage, fix would be to replace HDMI connectors. If connector are not damaged, then main unit of the TV has to be replaced.
Posted on Jan 06, 2010
SOURCE: LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
Posted on Dec 11, 2010
Mas Baz
  • 177 Answers
SOURCE: Hi, I have bought LG LCD
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Posted on Mar 21, 2011
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
LG LHT854 - the HDMI output will not work. LG tv shows 'no signal'. With RCA I can use the DVD function...the HDMI cable is ok! Is the HDMI output repairable?
hdmi is an in put on these, so you'll have to use a digital optical cable,
& for more than one device you'll need a digital optical switch box...
Jan 13, 2013 | Audio Players & Recorders
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
I've a lg 42ly95 the picture blacks out after 10/20 mins the sound remains,turn it off for 20 mins then back on picture ok,then the process starts all over again,sometimes if i put dvd on after the fault...
The problem. Comes down to a buffer board. KLS-420BDR-A This is the part number of the one in the TV which is hard to get as this looks like a common fault.. But there is any buffer board out there 6632L-0394C KLS-420BDL-C
KLS-420BDL-C Which the (c) is the(a) board main board .. Happy fixing people
Lg 42ly95 no picture fix
Feb 13, 2011 | LG Televison & Video
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
Lg 42' lcd cant get video signal i can get sound and menu pictures all come up. but no output from cable or ps3
I guess your either using the scart socket or the HDMI socket. You have gone into the menu and changed your input source to either HDMI or Scart havent you? Does your TV aerial input work when switched to Antenna on the input source menu. If these dont happen then you have a faulty main pcb.
Feb 13, 2010 | LG 42LH40 LCD TV
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
I have the LG Dn798 hooked up through my Yamaha receiver
Does it work via component or in a different HDMI port? If it does it sounds like either a bad HDMI input on the tv or a bad HDMI output on the receiver.
I would also verify that the receiver is 100% compliant with the HDMI standard as not all devices are.
Jun 03, 2009 | LG DN798
Hiran
Scott
Mar 22, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
