Question about Hunter Dryers
Ceiling fan makes high pitched noise - Hunter Dryers
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
debris caught iside pump assy is what it sounds like
SOURCE: high pitch noise
Try backing off on the screws that hold the fuser in place.Start with
the bottom right.
Posted on May 20, 2008
SOURCE: Samsung LNT3253H is making a high-pitched noise
I had the same issue. The tech that came out today removed the transformer on the power supply board, "resealed" it, and replaced it (re-soldered the same part back on) -- the transformer apparently vibrates because it was not properly sealed. BTW, mine was about the fifteenth that he has performed this repair on within the past couple of months -- all 32" and 26" Samsungs. Now, it appears to be absolutely silent.
Benimur
  • 6966 Answers
SOURCE: My ceiling fan - Casa Viejo
Sorry for the delay in response. Electrically, there should be no potential hazard since there would be no more "juice" running through the circuitry.
Posted on Nov 14, 2008
Our Ceiling fan is making noises when it's on.
hey Amy, Some brands of ceiling fans are notorious for being noisy,, What type of noise is the most important (or to be concerned about)... a clanking, binging, any high pitched repetitive sounds can usually be traced to an off-balanced" fan with something inside moving.. Now, if the sound is a constant, grinding, rubbing type sound, it needs to be investigated.. ceiling fans are not complicated.. its just an electric motor that drives 4 or 5 blades.... and has a light switch. If its grinding, the bearings are probably going bad.. They are not hard to replace if you have mechanical aptitude.. Go to the manufacturer's website.. they should have a trouble shooting guide,, check it out,, and also have a place for you to order parts..
Jun 25, 2017 | Dryers
Fan only wobbles on high....recently 'bumped'
Check all your screws especially the set screw at top of fan that goes into rod. Blades could be warped from the water. Ball of fan not set in bracket correctly. When your buying a fan, look for blade pitch.13 degree or better is best. You shouldn't have to use the fan on high unless it's a low-end fan with a low blade pitch. It's costing you more money to run the fan on high. Sorry to get so preachy, I'm a fan dealer .
Jun 19, 2013 | Dryers
Heater/air conditioning blower fan makes high pitch noise
Above the passenger's feet, 3 bolts to loosen and it comes right out...
Jun 05, 2013 | 1994 Mercury Capri
Noise
This fan isn't even worth fixing! When you're buying a fan,look for blade pitch or CFM's. Don't buy anything under a 12 degree blade pitch. 14 degree pitch would be better. Remember, you get what you pay for!
May 26, 2013 | Westinghouse Contempra Trio 42" Ceiling...
Someone helped me install a ceiling fan. I told them that I here a clicking noise still , they said to go back and tighten every screw. I did that but the clicking noise is still their. What are my...
Check that all the blades are aligned when the fan spins. If one blade is higher or lower than the others it throws the fan out of balance and makes a clicking noise. Also check that the pitch on all the blades is the same, this has the same effect. The blades can usually be bent just a bit to correct any misalignment.
Jun 09, 2011 | Hunter (25417) Ceiling Fan
My laptop makes a high pitched noise
The high pitched noise you hear is most likely caused by the CPU cooling fan on your laptop. If you suspect that this high pitched sound is caused by the fan going out, you can spray your laptop with compressed air to get the dust off of the fan.
This solution will make your laptop work at a cooler temperature, and reduce the noise.
If the problem persists, seek a certified laptop repair specialist.
May 22, 2011 | Computers & Internet
Moves to much when on high and makes noise. It
mcdevito75, I would have a handy man look at the Fans hook up to the ceiling to make sure it:s still tight. The fan vibration could have looened it from the ceiling do not us efan on high till it:s checked, handy man / women in every area, just ask around.
Jul 18, 2010 | Hunter (25417) Ceiling Fan
New Broan fan rattles
I would take it back for exchange...
($159... is high end pricy... Amazon = $168 (worse)).
Old ... tired fans can dry out... gather dust.
Their life can be significantly extended with
fresh lube... As for me...
I've learned to just find & buy a NEW MOTOR.
But a new FAN... Outrageous!
Take it back
... Broan-NuTone Nutone Is a QUALITY
FAN... Expect quality.
Apr 20, 2017 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
Ceiling fan
Nov 14, 2008 | Dryers
Dryers Logo
544 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
