Question about iRiver H10 MP3 Player
Iriver H10 Scroll Pad Sticking
After lending my Iriver H10 to my wife, who subsequnetly left it out in the Dubai sun covered in tanning oil, I have been having problems with the mouse / scroll pad not responding. Resulting in me being unable to make up / down movements through the menu structure. Any help would be appreciated, Even if its just someone who can repair it in Dubai. Cheers Aky
  • parrausmc Nov 16, 2007
    my scroll pad does not move
  • jdollz Dec 07, 2007
    how do you open the i river h10 20 gb player casing to fix scroll pad, what type of tool and size is used.thanks
My Daughter's iRiver scroll pad must be just keeps scrolling. She says nothing happened to it. Never got wet etc. I am going to attempt to open it and see what it looks like. The one post says it is very easy, but gives no information. I called the company and they have no USA service centers at if it is out of warranty you are out of luck. They say they hope to have a repair center soon...but it sounds like a company running out of a garage. Good luck and buy some other brand.
Posted on Dec 19, 2007
  • Spotman Dec 20, 2007
    OK I took it apart last night.
    You will need a # 5.5 torx bit and a # 0 Phillips preferably magnetic.
    Remove the 2 top screws and 2 bottom screws. Note the top ones are longer.
    Keep track of which screws come from where...there are slighty different types inside.
    Open the case from the top...using a Jewelers mini flat blade screwdriver lift the tab and open case. There are tabs on the sides as well and it takes some care and fingernails to snap apart.
    Once open, the two halves hinge from the bottom ribbon wires. They do not need to be disconnected. Lay the halves flat and take out all the screws from the top board side. Watch where wires and clips are held on with the screws. which screws come from which holes...some are slightly different than the others. Lift the circuit board from the front case. The scroll bar assembly will be loose. You can pull out the 4 conductor ribbon cable. I took mine out and removed it from the dress bezel. Other than that, the scroll bar seems to be a sealed unit and doesn't look like you can do anything to clean it. I put it back together and now it works.
    It would be nice if the part were available somewhere.
  • 175 Answers
You can open your player its very easy, and clean the pad.
Posted on Aug 23, 2006
How to download free download driver iriver iriver h10 5GB
go to:
(Make sure your popup blocker is on, the site loves popups) Scroll down a bit and input the security code to get the file. Save it to your desktop and when it's done, choose to Run it and then install it. Make sure the device is UNPLUGGED when you install the driver. Hope this helps!
Nov 10, 2010 | Computers & Internet
Need to reboot iriver h10 cant delete songs
Ok , sorry it took me until now to answer , this is a very simple procedure and I promise it will fix your Iriver! All you have to do is go to main menu , scroll down to settings . Then go to additional settings and at the very bottom select " Database Refresh " . This will fully reboot your irvier H10 , and will flush anything harming your mp3 device .
Hope this helped :)
- Chris
Feb 15, 2010 | iRiver H10 MP3 Player
My iRiver H10 scroll doesn't work
for tips on fixing the H10 with problems -- try this website.
From what i have seen, your scrollbar is in need of replacement. Need to buy a cheap as-is unit from ebay, get tools to open your H10, and replace the defective part.
Apr 01, 2009 | iRiver H10 MP3 Player
Opening for repair the iriver h10 20gb
I am having the same problem. Resetting it doesn't work and now it's locked all the time and I can't do anything with it! There are no suggestions on the iriver website. Have you got any other solutions to this problem?
Dec 07, 2007 | iRiver H10 MP3 Player
IRiver H10 20GB MP3
lcd cleaner
schout - water damage = irreversible
May 28, 2007 | iRiver H10 MP3 Player
Defective Scroll Pad iRiver H10 20Gb
As stated above the 5/6gb units and the 20 gb units use the same scroll bars but they sit on different metal platforms. The platforms are not interchangable. The only way to do it is to remove the old/broken scroll bar from the 20gb metal platform. Then CAREFULY peel the working scroll bar off the 5gb platform be very careful the unit is in multiple layers of plastic and is very FRAGILE. Re attach the working scroll bar to the 20 gb platform and gently plug the little tail into the slot on the motherboard.
OR, buy a working 20 gb scroll bar from ebay. two screws and you're done.
Apr 21, 2007 | iRiver H10 MP3 Player
Touch pad stopped working.
Unfortunately no there is not. These players are basically disposable. If your out of warranty then you should get a new one.
Oct 31, 2006 | iRiver H10 MP3 Player
Iriver backlight not working
Take the battery out and put it back in again.It worked for me!
Oct 02, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
641 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
