Question about Canon T90 35mm SLR Camera
T90 won't power up
After six months without batteries my Cannon fails to power up. Connections have been cleaned to no avail. Any ideas? Has a processor failed?
    Top Expert:
  • Canon Master
  • 14,161 Answers
Posted on Jul 18, 2016
2 Suggested Answers
  • 23 Answers
SOURCE: The internal batteries have failed on my Canon T90 camera & I cannot find them to replace, Where are they ?
Hello!
Southern Photo Technical Service is a Authorized Service Center for CANON.
We do service the camera model you mentioned and the standard cost
to Replace the internal battery, Clean, Lube, Repair and Adjust all functions to meet manufacturers specifications is $98.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
Posted on Jun 04, 2009
Lens mount fit
None directly. The T90 was the last Canon camera to use the older FD lenses. All newer Canon SLRs, film and digital, use the EF mount. However, by using an adapter such as http://www.rakuten.com/prod/adorama-canon-fd-lens-to-eos-body-adapter-with-correction-glass/216466533.html?listingId=120668308, you can use the old lenses on any Canon digital SLR.
Aug 12, 2013 | Canon T90 35mm SLR Camera
Shuts off and won't charge batteries
What does the unit do without the batteries attached? Try re-seating the connections.
Is this the same behavior as before you replaced the batteries? If so, the unit itself has likely failed and will need to be replaced.
Dec 30, 2012 | APC Back-UPS RS 800VA UPS System
Do i have to remove battery cables to store for 6 months
no. just charge chair every four to six weeks without fail for a 12-24 hr period each time. you can disconnect them, but for battery health and longevity keep them charged
Nov 09, 2012 | Invacare Pronto M51 Power Wheelchair
Canon T90 haven't used camera for 6 months, new batteries in camera will not function at all, was 100% O.K. when last used, any ideas please
Check to make sure the replacement battery or batteries are correctly installed. There should be some type of diagram in the plastic or label showing the correct orientation. IF the batteries are correctly installed and the T90 still persists in not operating then remove the batteries and clean all the terminals/connections either with a new rubber on the end of a pencil. I have as much as I hate to admit left batteries in my gear and had to resort to abrasive paper affixed to a new pencil to get down inside the battery chamber to clean the contacts. Also and I hope this is not the case the T90 has an internal battery and if this is dead then I'd suggest sending it to a repair facility. Most service places will clean lub and adjust and replace the battery for about $100.00 and Yes the camera is worth it even today in our digital world
Nov 24, 2010 | Photography
The menu button, tools button and others do not work. Did I do something to lock these buttons? Power, volume, channel etc. operate properly. Less than six months old.
The remote is having problems with it circuit board or it CPU chip is failing.Take the remote aparts,take some Q tips dip it in some rubbing alchahol clean the circuit board and those - + battery circuit connections terminals.Wait like about 20 mins,than put the remote back together again.Now,all the contacts points ben cleans out.The remote should work again,not than the remote CPU is failing,sorry now the remote is garbage.Try website like Remotes.com to buy an exact remote or very close to the orignal remote.
Nov 08, 2010 | Samsung TV Remote Control
Hello!
Bring it in, or
Send it to:
37 NE 167th Street
Jun 03, 2009 | Canon T90 35mm SLR Camera
1989 Ford F-150 won't start
I have found that Ford products are very sensitive to poor grounds and poor connections at the battery or starter/ starter solenoid. Clean all grounds and terminal connectors really through. Don't just look and judge them to be clean. After market add on battery clamps will corrode where you put the cable into them. Be sure to take them apart and clean there also. Also ck to be sure your battery is putting out the cranking amps it is
rated at. If not sure take it to a shop and have it tested. Good luck.
Dec 04, 2008 | 1989 Ford F 150
JVC HX-D7
I had a similar problem, and took it to an authorized repair shop(under warranty), the kept it six months, and JVC finally admitted there are solder connections with that model, and six months later, we got a new unit. I will buy Sony next time
Sep 16, 2007 | JVC HX-D7 Shelf System
WILL NOT PRINT CD DISCS
You could try uninsatlling it completely and reinstalling it again with printer driver disc.
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon T90 35mm SLR Camera Logo
142 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
