Question about Refrigerators
Water is pooling on the floor of the freezer Model#PFSF2MJXA
  • 58 Answers
SOURCE: refrigerator/freezer
Seems that the condensate drain is clogged/frozen.. If there is a bottom storage bin on the freezer side, remove it. There should be a removeable panel on the back freezer wall. If you can safely remove it then do so. Look for an accumilation of ice behind the panel, under the evaporator coil. Do not attempt to do this unless you have a good mechanical aptitude. One other thing you may try is to clean the coil underneath the refrigerator. This can be quite difficult as the unit must be tilted in such a way as to gain access. The coil there is most likely covered in dirty hairballs. Once the coil is clean, let the unit defrost overnight. Once again, do not attempt any of these steps unless you are certain you can handle it. Perhaps it would be best to call a qualified service tech.
Posted on Sep 11, 2008
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
woodchuck789
  • 4070 Answers
SOURCE: no water supplied from samsung fridge freezer and
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 13, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water is pooling in the bottom of the freezer
Posted on Nov 16, 2009
Testimonial: "THANKS... it's all defrosted and cleaned out and will wait to see what it does tomorrow after it's all back up and running again !! Thanks !"
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
I am also having ice form in the bottom of freezer The seal is good. I do notuse the ice maker or the water dispenser. If I do not continually break up the ice, the water leaks onto the floor. Very...
That ice build up is their because the drain for the automatic defrost is blocked so instead of the water from the defrost running through the drain down into the pan at the bottom its pooling in the floor of the freezer and freezing up. by clearing the drain it will drain away instead of pooling up in the freezer....unfortunitly you didnt give your brand or model number so i can give no advice on how to take apart the freezer to clear the drain but can tell ya once ya figure out how to do it that will solve the ice problem.
I little insight in how to do it...typically on most freezers the back wall comes off,in a few cases its the floor that comes out but typically the back wall is what ya would remove.
GENE
Sep 25, 2011 | Refrigerators
Kenmore refrigerator model 363-58572892 side by side refridge/freezer. Water is appearing on floor in fron of freezer side. Appears to be coming from ice maker. Crack in cce mold? Clogged drain? filling...
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 29, 2011 | Kenmore 64802 Top Freezer Refrigerator
Why does Ice build up at the bottom of the freezer side of my Kenmore side by side refrig model # 106.54602300? Purchased in 2003 Thanks Mark
Gene
Aug 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Maytag side be side model msd2454gr
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I have a top freezer model and every morning their is a small pool of water in front on the floor. I checked the bottom tray in the back and drip tube and they seem to be ok. I noticed in the door that...
These doors are not water cooled. Is there water in the drip pan? Likely not and the drain is froze over with ice. you will have to remove the rear panel inside the freezer and clean the drain. There is most likely ice under the freezer floor that needs removed also. Take your time and do not damage the styrofoam separator and air channels.
Eric
Aug 27, 2009 | Refrigerators
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Water leak
If the water is coming from the inside of the freezer (you will see ice build up on the freezer floor) then the drain is frozen over and will need to be cleared using hot water.  If not and if your model has a dispenser, then check the water line connector from the bottom front of the fridge to the freezer door.  Let me know what you find.
Oct 19, 2007 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
