Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer cloths take at least 2 full 60min cycles before cloths dry .....do you think its my element? if so where about is it in my dryer?
  • kategeorgeco Dec 04, 2008
    my dryer is also taking 2-3 cycles on high to dry. what should i look into?
  • 550 Answers
Not element, same element runs Hi and low temp
whirlpool dryers have 2 thermostats,
40degreeC (low)100F
60degreeC (high)140F
the 60degree thermostat has failed
cost is between $15 and $40 depending on how the 'parts guy' feels on that day
the dryer is easy to open, check any of the 'change belt' questions or Joks instruction brief
Posted on Oct 29, 2008
Whirlpool dryer 5 cycle 3 temperature not getting hot to dry clothes. Dryer is over 15 years old
ever think it is wore out and needs professional help .elements burn out eventually
Dec 31, 2016 | Whirlpool Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
Not drying as quickly, requires 2 cycles
look inside your lint trap to see if it is clogged. Also remove your vent hose to check for clogs there and at the outlet. make sure your hose isn't kinked.
Jul 20, 2009 | Whirlpool GEW9200L Electric Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer
Check your vent system. I had the same problem until I checked the vent outside my house and it was clogged with lint and ice. It has worked amazingly since!
Oct 26, 2008 | Dryers
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Kenmore dryer isn't working
was the previos dryer taking a long time to dry??? Make sure a high velocity of air comes from the dryer with the vent unhooked there may be a internal restriction causing the long drying times, if there is no restriction then it is in the home vent line. To verify that it is a vent issue unhook the vent and do a load of clothes if it drys in 40-60min it is the vent.
Sep 29, 2007 | Zanussi TC180W Electric Portable Dryer
Whirlpool LER4634J Electric Dryer Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
